Q7 trailer hitch Photos
I went to the search to see if there were past post about the trailer hitch and noticed that there are questions about what it really means "Trailer Hitch". What do you really get when it says trailer hitch package?
If you are using the 2" receiver format, you will need a wiring (RV) socket and a hitch bar w/ball. These are discussed in other posts. search tow wiring etc. Sockets can be purchased online for as little as $15.00 and bar/ball combos at your local towing center, Sears, Walmart etc.
I copied a link from someone, cant remember who, of an adapter for wiring socket see link. These are previous threads re same.
https://forums.audiworld.com/q7/threads/710.phtml#3895
https://forums.audiworld.com/q7/threads/566.phtml#3027<ul><li><a href="http://www.etrailer.com/mm5/merchant.mvc?Screen=PROD&Store_Code=E&Prod uct_Code=11775&Category_Code=VWH">etrailer.com </a></li></ul>
So I just need to get the removable receiver/tow bar with ball and the wire Av connector? I want to make sure that the main tow frame is installed to the frame of the Q7
WVA6
13
01-27-2009 06:54 AM
Merkin
05-29-2005 05:01 PM
