Q7 V12 Aluminum Pedals
#21
Wear gloves or place a towel over the aluminum brake cover when you install it because the manufacturer didn't debur after cutting. I sliced up my thumbs pretty bad trying to snap the brake cover into place. There were no issues with the dead pedal or gas pedal.
Hopefully this post will prevent others interested in this mod from learning the hard way like me.
#22
One quick word of advice...
#24
Can someone tell me the process to install them?
Do they just snap over the pedals and I read where the foot rest on the left takes a screw.
Like to know before I buy.
Also someone mentioned the VW fits, anyone use it as well?
#25
I have the Audi oem so I can't comment on VW. The dead pedal requires a screw but the brake and gas pedals are slip ons.
#27
The dead pedal has a single T20 torx screw that you can loosen with your hand. The gas and brake pedals simply slip on; I used Q tips soaked in soapy warm water to 'lube' the outer back edges of the aluminum pedals slid into place with ease..install took less than 10 minutes total.
#28
Anyone know where to find RHD ones. It says in the description not suitable for RHD. I can understand that on the dead pedal since it will be at a different edge for which side the dash is on but surely the pedals are the same.
mudd
11
09-29-2002 06:39 PM
Jeremy Clarkson
9
01-01-2002 08:02 AM
