Q7 wiper fluid fill indicator will not turn off
#11
Part number for sensor is 7M0 919 376. I found one on ebay for under $10, there were some cheaper but many places were out of stock. The dealer wanted $40. Just remove a few torx screws that secure the liner behind the passenger side front wheel. Pull liner back and the washer bottle is right there. The sensor fits into a rubber grommet. unplug sensor connector and just wiggle/pull old sensor out. Have a bucket handy because the tank will drain once you get that sensor out.
#14
AudiWorld Expert
unfortunately so... typically i use the bmw washer fluid or prestone but i was on a small road trip and picked up two gallons of it... then this happened... apparently rain-x changed their formula and other have experienced the same issue from what i am finding out with my minimal e-research.
have you or others had the same experience or this just coincidence?
#16
#18
Solid work, guys!
Some good detergent fixes this if your issue is Rain X... i didn't even have to buy the new sensor.....
Now... anyone know how to get to the same part on my wife's 08 A6 (3.2?)
#19
AudiWorld Expert
what kind of detergent? where is the sensor located?
i am under warranty so i am not too concerned but down the road if the issue presents itself again i would like to address it myself.
#20
