Rear Aircon Controller issue
Anyone had issues with the rear aircon. I have had the rear delux aircon switched off for a week or so. Yet when I turned the key in the ignition today it the rear aircon sprang into life and blasted air into the back of the car. It does not respond to any of the buttons on the rear control unit. When you press any of them it switches from displaying the temp of 22 degrees to showing dashed lines. The aircon fans can be turned down from the MMI unit, but not turned off.
Anyne seen anything similar or is this one for the stealer (though assume any work would be a warranty job)
Thanks
Thanks
Perhaps you reset it via the Auto button...or other key?
If you press and hold (I think) or press twice (I cant remember which)the drivers button you reset all settings to your choice overriding previous settings.
The second scenario is you used the other key with its presets selected.
Re: Are both child lockouts engaged? The rear controls will change to ---- if they are engaged and
Folks, thanks for help. Turned drivers side child lock off. Turned ignotion on and off and hey presto it was reset.
Delusory
04-30-2016 01:15 PM
yamahapro361
01-10-2003 07:46 PM
