Rear screen washer
#11
Solved it for me
Don't know if you have the same problem as me but my jets were blocked on the rear window.
Easy fix, just pop off the plastic round cover at the bottom of the wiper ( covers the bolt that goes into the window ) then pull off the black plastic jet which is the thing that angles the jets to the window.
At this point try the rear washer yet to see if this is the problem as if it is you should get a jet of water shooting straight back. If it is the problem simply push a needle done the jets to unblock and refit.
Make sense ?
Make sense ?
Highpark
Q5/SQ5 MKI (8R) Discussion
11-29-2013 02:08 PM
achtung
08-08-2001 06:45 PM
