Sttering Wheel Volume Knob
Anyway to switch the volume **** and the dash panel **** on your steering wheel? I'd prefer volume control on my left hand
I'm not sure how the controls are wired in the steering wheel but, if it's possible, pull the steering wheel and mount it 180 degrees from the normal position to reverse the controls from left to right and vice versa. The placards will be upside down, but you can still figure out which is which. Other than that you may have to break out a soldering iron and rewire the switches. Just make sure you disconnect the airbag and/or the negative battery terminal first.
alekaras
Audi A3 / S3 / RS 3
08-18-2005 05:36 AM
