Thule 440 with 53" bars will fit our Q7?
Hello all,
I'm going to get a nice used Thule 440 2 53" bars & locks. Please let me know if there will be any issues while mounting them. The clamp look like this
<a href="http://s184.photobucket.com/albums/x193/Bmle06/Q7_3_28_08/?action=view¤t=Clamp.jpg" target="_blank"><img src="http://i184.photobucket.com/albums/x193/Bmle06/Q7_3_28_08/Clamp.jpg" border="0" alt="Clamp"></a>
<a href="http://s184.photobucket.com/albums/x193/Bmle06/Q7_3_28_08/?action=view¤t=IMG_0615.jpg" target="_blank"><img src="http://i184.photobucket.com/albums/x193/Bmle06/Q7_3_28_08/IMG_0615.jpg" border="0" alt="Photobucket"></a>
<a href="http://s184.photobucket.com/albums/x193/Bmle06/Q7_3_28_08/?action=view¤t=Bar_length.jpg" target="_blank"><img src="http://i184.photobucket.com/albums/x193/Bmle06/Q7_3_28_08/Bar_length.jpg" border="0" alt="Bar length"></a>
Thanks,
Thanks,
it seems that the roofrail are a bit too close together for direct use of that system.
Perhaps you could keep/post a photo record if you do have to modify them.
The 53" seem to be a desirable size.<ul><li><a href="https://forums.audiworld.com/q7/threads/3894.phtml#24975">https://forums.audiworld.com/q7/threads/3894.phtml#24975</a</li></ul>
The 440 set that is sold domestically has 47" bars which seem to fit just right, just long enough to clear the feet on either end - See link pic below:
440 Stock bars.
http://pictureposter.audiworld.com/119600/img_1116.jpg
The Aero bars that come with the UK version of the foot pack, seem to have longer bars that stick out farther, probably 53"
See pic below
UK Aero bars
http://pictureposter.audiworld.com/85357/dscf0293.jpg
i prefer the shorter bars, and am planning to buy the UK fit kit for the U.S. 440 set so that there is not a gaping hole, that apparently "whistles" a bit when driving.
the $12 Euro fit kit from the UK site can be purchased here:
http://www.roofrackshop.com/vehiclecheck/audi/q7/
440 Stock bars.
See pic below
UK Aero bars
Probably won't be an issue, but it just doesn't look right - like it needs a different fit kit.
The Aero version is the fitted version from the UK that uses the correct fit kit to fill in the gap above the rails.
The pic of the 440 with the gap is without the correct fit kit. That kit can be purchased from the UK for $12 euro and will look like the Euro kit ---
Both kits use the same feet, but require the correct fit kit to have the finished look for your specific car.
Next will be the hitch, but the after market hitch seems to be higher than factory one. I have to see. I will design running boards with 3/4" or 1" copper bars, but they're not needed per wify...
Cheers,
Cheers,
I'm not sure if the guy who installed and put pics on this board made a bumper install error and it was mounted wrong.
The mount of the hitch is simple and cant be screwed up, but i cant believe curt would design their mount that jammed up into the bumper.
good luck with the 440, and just so you know, the fitkit from the UK totals $30 Euro for item and shipping to US.... thats $47.93 USD
When you get around to removing the bumper cover or look at a Bentley manual, you'll see what I mean. There is *no* free play on the bumper install. I actually removed/reinstalled it twice to double check.
Incidentally, the Curt hitch isn't designed specifically for the Q7 and was initially designed foe the Touareg and Cayenne. I may end up dremeling the bumper to get a more "proper" fit, but doing this would be purely for cosmetic reasons.
I recently did an allroad fender flare replacement and stuff didn't go back the way i wanted, and without slamming it with a rubber mallet, it wasn't going where i wanted it to go.
So, it's the way it is.
it's a bummer the hitch fits like that -- a 1/2 inch would have made a big difference, but since it was close to $1000 difference from the dealer installed - i'm sure i could live with it on a leased car.
I sometimes think about selling the Curt and buying an OEM one, but for my primary purpose (bikes) there is no functional difference. The OEM hitch comes with a trailer control unit which integrates with the rest of the car's electronics which would be quite beneficial if I need to tow my parent's boat.
S4@last!::Now B7 RS4
Q7 MK 1 Discussion
11
07-28-2008 06:56 PM
adminisTerTurbo
Audi Original "S" Cars
03-05-2008 08:27 AM
MachineMan
Q7 MK 1 Discussion
08-26-2005 12:55 PM
