Towing Capacity Q7 vs. Toureag
Can someone help me here...There is not much info on the web that clarifies this.
Q7 stated towing capacity with tow package is 6600lbs.
the VW Toureag TDi is 7700lbs.
Are these vehicles not similar frame and same engine?
Why the difference?
Is the 6600lb. Q7 rating accurate or is it more?
Thinking if getting an Airstream 27/28 and not sure if I can pull it or not?
Also, VW TDI list's a range of 700 miles??? WTF are they just making up numbers?
thanks,
Tracy
Why the difference?
thanks,
Tracy
The longer wheel base of the Q7 should help with towing stability.
It's the extra weight that hurts it in terms of tow capacity.
VW gross weight = 6173 lbs.
Q7 gross weight = 7044 lbs.
That accounts for 871 lbs difference right there.
So why can the Touareg tow more weight? It all comes down to the distance from the tow hitch to the back axle. The secrete to Touareg is how close the ball is to the rear axle and this puts the tongue weight on the axle without much of a lever. The further back you put the ball the more of a lever. The Q7's rear hangover is just long enough to make a difference... it's enough that you would really feel 7000+ pounds back there pulling side to side and up and down. The Touareg and Porsche (and probably the Q7 as well) require (if you listen to VW/Audi) a specific trailer receiver that is very short (puts the ball very close to the back of the car.) They specifically warn against using anything longer. The VW/Audi part is also solid steel and is very heavy and cost about $100. I managed to pick mine up from the local Porsche dealer for $50... mainly because the parts guy couldn't stand selling me a $100 trailer hitch. If you go with the VW setup the Touareg doesn't even start to stumble at 7700 pounds.. you can safely tow that much and never feel like the thing is struggling. My V10 also has huge brakes.. so that helps but I never had any issues stopping with the Q7 either.. they both stop very very quickly with the boat hooked up. Obviously the V10TDI wins when it comes to power. The difference is that the Q7 can tow up a steep mountain pass and maintain 65-70 MPH... with the Touareg you can be going up that same pass and easily accelerate and pass someone without any struggle at all. IF we could get the new 4.2TDI in the Q7 over here I'd order it (and new Touareg 4.2TDI) in a heartbeat. The new V8TDI is significantly improved over my V10TDI... and it's hard to believe there was room for improvement.
Anyway... that's the story and my experience.
OneEighth
06-15-2002 08:55 PM
