Towing on Q7
Towing on Q7
I'm thinking about installing a tow hitch on my 08 Q7. The tow capacity of 4.2 and 3.6 are same at 6600 lbs. How did they have same capacity? and my real question is that can 3.6 V6 really pull 6600 lbs without any problem? Thanks in advance.
I believe the 6600 lbs is only if the tow hitch was installed at the factory. If retrofitted, then the limit is dropped to 5500. Factory installed includes some tranny updates (i.e. cooling) that a simple retrofit cannot accomplish.
I have the 4.2 and tow a 3500lb tent trailer with no issues. I can feel the weight but once going, the Q7 does a great job with it. The torque difference is only 60 (325 V8/265 V6) so its just a matter of how quick you want to get up to speed while towing. I picked the V8 specifically because I didn't want to stress the engine as much; I like to get up to speed.
Hotsauce; Not really, same suspension, brakes, wheelbase and approx weight. Other considerations like tires, chassis strength, lug nuts are the same. Cant see Audi going out on a limb anywhere. Just enjoy the extra winding power that makes the hills seem flatter.
As far as doing a side-by-side, not sure how that would work. Do you tow something heavy uphill until one of the cars blows up? Don't sign me up for that!
If such a thing does exist, it should be in the Q7 parts list. Which if so, should also be something we could install along with the tow package.
Jim VP
From my initial review and questions on the tow package, from what I was told, if you order the tow package from the factory, the under frame is different and you get the increased cooling capacity. Not sure yet if the cooling capacity is both engine and transmission. I do know that with the tow package, because the under frame is different, you can't get the stock running boards. The mounting points are not there with the tow package. Probably why the towing capacity is higher from the factory then with the dealer installed or after market receiver hitch.
