Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Trailer Wiring Help
Old 04-22-2017, 08:38 PM
  #31
-Wes-'s Avatar
Yeah, and that would be fantastic. But, you also have to drop the dough on it. For my purposes, it wouldn't be worth it. So far, I've used it two different times to pull a trailer. One was a dual axle 6x12 enclosed U-Haul, and one would be hard-pressed to know it was even back there. The second was a car-hauler: I moved a 2010 Subaru Forester with it. I could have used to adjust the positioning of the car to be better balanced to put less weight on the Q7, but, aside from that, it pulled it beautifully.
I suppose if you pulled trailers regularly or needed it for a very long trip, springing for the factory harness might be worth it.
Old 04-28-2017, 07:57 PM
  #32
cuatrokoop's Avatar
I added the factory stuff to my '07 3.6 (but no bigger coolers), and my '07 4.2 w/factory air came with the tow package and I added a brake controller. My 20ft enclosed car trailer pulls great behind it...
Old 06-09-2019, 07:01 AM
  #33
Tony Cas's Avatar
Default Trailer Hitch harness part number #
Originally Posted by Jusforfun
The bit I fail to get is... do we need this part? Every time a person asks about electric trailer brakes this comes up as there is a connector behind the footwell that is wired back to here but it must be connetced to a variable voltage switch which is physically connected to the brake pedal.
I do not have the electric trailer brakes but do have the control module/unit. Not sure how you are going to connect without it.
mksap11 also posted this pic while he was doing his own curt install.
So can you just connect direct to the harness?
How will you overcome bulb fail screen?
Attachment 79772
can you please tell me the trailer wire harness part number?
Old 05-10-2020, 02:56 PM
  #34
Jack Wu's Avatar
Here you are:
Wire harness Part #: 4L0-971-124-F 4L0971124F
Old 09-30-2020, 05:39 PM
  #35
Mike IL's Avatar
Thanks, Wes, for the pictures - very helpful. Where did you connect your 12V power? To the battery? To the fuse box in the rear? To the 12V plug in the rear?
Donny Sandau
10-26-2006 06:51 PM
A4 Moda
01-20-2006 07:07 PM
smdepew1976
12v V6 Discussion
26
02-15-2005 04:48 AM
Yanni
09-30-2003 07:13 PM
Quick Reply: Trailer Wiring Help
