Unlocking Bluetooth on Q7
Hi,
My car does not come with bluetooth function by default as its considered an option. I was considering to get one after market which was proving very expensive here to set up.
I found following on one of the local forums here in Hong Kong to unlock the bluetooth as it seems hardware is there but require software unlock.
"Unlocking the MMI Hidden menu
select control module 5F in vag-com
select adaptation -10"
select channel 6
set value to 1
press test
press save
press Done close software
press car+setup for 6 second to reboot
Unlock Bluetooth
in hidden menu
main/diagnose/settings
aux/ami. BT/ no -AMI
tel setting misc no WLAN / no NAD/BT/HFP
Vac-com block 5f channel 17 put 1
Does any one knows about this and if some one tried it?
Thanks.
select channel 6
set value to 1
press test
press save
Unlock Bluetooth
in hidden menu
Thanks.
KiwiS4
Q5/SQ5 MKI (8R) Discussion
02-07-2017 10:26 PM
xradman
14
07-23-2014 06:40 PM
rexwilson
VAG-COM Discussion
08-03-2004 05:35 PM
coupesta
12-06-2002 01:50 AM
