V12 Front Bumper.
I have the s line front bumper at the moment and want to change it to the V 12 bumper with the LED Lights.
My dealer is however not aware of how to handle the wiring for the bumper. What will happen to the wires from the fog lights etc? Which wires will go to the LED lights? I currently do not have daytime running lights.
Can anyone help?
Thanks
Can anyone help?
Thanks
Berns Man, the v12 bumper is not gonna work by it self you need to have the fender flares to. I had to order those to make mine work, as far as the lights you will loose your front turn signals to make the day time running lights work.... Its alot of work....
Yeah, I will be ordering the whole kit including the fender flares and the rear bumper.
Just worried about the lights in front, and am even more worried because my dealer is not too sure what to do.
Oke,
Your headlights has 2 reflectors outsite is Xenon inside is daylight. In your bumper there are the flasher bulbs. These have to be removed for the DRL's. The flasher bulbs you have to buy 2x 21W or 2x 10W these you have to replace for the daylight bulbs.
The connection from the flasher bulbs you solder and go up with them to the daylight bulbs. The connections of the daylight bulbs you have to solder and bring them down to the DRL's at last you put 2 connections from the DRL's to your body computer no. 09 (zentral mechanic) I have to look wich pins do you need to use. After the install you have to recode the 09 and tell the computer that you have installed DRL's.
Also have the parts numbers but can't get them anymore by the Audi Dealer European block at this Part number to garanty the exclusivity of the 6.0 L V12. So if you can get them please let me know so you can send some sets to me! I despered ...........grrrrr need them!!!!!
Greetz CARlectra the Netherlands
loose your front turn signals????? Nope replace them in the day light bulbs look at my picture!
Can anyone help?
Thanks
Can anyone help?
Thanks
bcalmac
Q5/SQ5 MKI (8R) Discussion
08-31-2023 09:11 AM
bac2h
06-28-2012 08:54 AM
Mario S6
11-18-2005 05:24 AM
