Vaccum pump and misfires
Hello, I just purchased the Ross-Tech to diagnose my 2007 Q7 4.2 FSI.
There are some weird issues, it seems the vacuum pump doesn't work that well after the vehicle is stopped.
Because of this, and with the battery still flat, I can charge the battery and leave it disconnected and all is well, I did a load test on the battery and it's still good. The alternator also seems to be working fine, so what causes the power consumption and the battery to die when driven normally.
what did you think about these faults and what components were damaged?
I will post the scan of my first diagnosis. Any advice would be good.
Code:
Chassis Type: 4L (4L0) Scan: 01 02 03 05 06 07 08 09 0E 0F 14 15 16 17 18 19 1D 1E 20 27 28 2E 34 36 37 3D 3E 42 46 47 4C 4E 4F 52 53 55 56 57 5E 5F 61 62 65 66 67 6C 6D 6F 72 75 76 77 7F VIN: WAUAV54LX8D004288 Mileage: 199300km-123839miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: Cannot be reached 1100 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: Cannot be reached 1100 14-Susp. Elect. -- Status: Cannot be reached 1100 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 18-Aux. Heat -- Status: Cannot be reached 1100 19-CAN Gateway -- Status: Malfunction 0010 1D-Driver Ident. -- Status: Cannot be reached 1100 1E-Media Player 2 -- Status: Cannot be reached 1100 20-High Beam Assist. -- Status: Cannot be reached 1100 27-Ctrl Head, Rear -- Status: Cannot be reached 1100 28-HVAC, Rear -- Status: Malfunction 0010 2E-Media Player 3 -- Status: Cannot be reached 1100 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: Cannot be reached 1100 37-Navigation -- Status: Malfunction 0010 3D-Special Function -- Status: Cannot be reached 1100 3E-Media Player 4 -- Status: Cannot be reached 1100 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4C-Tire Pressure II -- Status: Cannot be reached 1100 4E-Ctrl Head RR -- Status: Cannot be reached 1100 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Cannot be reached 1100 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: Cannot be reached 1100 5E-Ctrl Head LR -- Status: Cannot be reached 1100 5F-Information Electr. -- Status: Cannot be reached 1100 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Cannot be reached 1100 66-Seat, Rear -- Status: Cannot be reached 1100 67-Voice Control -- Status: Cannot be reached 1100 6C-Back-up Cam. -- Status: Malfunction 0010 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 75-Telematics -- Status: Cannot be reached 1100 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: Cannot be reached 1100 7F-Inform. Electr. II -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Labels:. 079-907-560-BAR.clb Part No SW: 4L0 910 560 H HW: 4L0 907 560 A Component: 4.2l V8/4V 0020 Revision: 71H21--- Serial number: Coding: 01210010190F0560 Shop #: WSC 31414 790 00001 VCID: 2D51BCB3B41137EE88-8078 7 Faults Found: 000017 - Bank 1: Camshaft A (Intake) P0011 - 004 - Retard Setpoint not Reached (Over-Advanced) - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 17:39:50 Freeze Frame: RPM: 1104 /min Load: 51.0 % Speed: 4.0 km/h Temperature: 64.0�C Temperature: 43.0�C Absolute Pres.: 1020.0 mbar Voltage: 13.462 V 005241 - Brake Boost Vacuum System P1479 - 008 - Mechanical Failure Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 17:40:22 Freeze Frame: RPM: 1759 /min Load: 57.6 % Speed: 17.0 km/h Temperature: 63.0�C Temperature: 41.0�C Absolute Pres.: 1020.0 mbar Voltage: 13.335 V 000768 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 17:41:30 Freeze Frame: RPM: 661 /min Load: 30.2 % Speed: 0.0 km/h Temperature: 54.0�C Temperature: 20.0�C Absolute Pres.: 1020.0 mbar Voltage: 13.335 V 000769 - Cylinder 1 P0301 - 001 - Misfire Detected - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 17:41:30 Freeze Frame: RPM: 661 /min Load: 30.2 % Speed: 0.0 km/h Temperature: 54.0�C Temperature: 20.0�C Absolute Pres.: 1020.0 mbar Voltage: 13.335 V 000770 - Cylinder 2 P0302 - 001 - Misfire Detected - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 17:41:30 Freeze Frame: RPM: 661 /min Load: 30.2 % Speed: 0.0 km/h Temperature: 54.0�C Temperature: 20.0�C Absolute Pres.: 1020.0 mbar Voltage: 13.335 V 000771 - Cylinder 3 P0303 - 001 - Misfire Detected - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 199279 km Time Indication: 0 Date: 2022.02.28 Time: 18:01:55 Freeze Frame: RPM: 1107 /min Load: 30.6 % Speed: 20.0 km/h Temperature: 96.0�C Temperature: 28.0�C Absolute Pres.: 1010.0 mbar Voltage: 13.843 V 004952 - Cylinder 2 Ignition Circuit P1358 - 004 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 199282 km Time Indication: 0 Date: 2022.02.28 Time: 18:10:42 Freeze Frame: RPM: 2828 /min Load: 89.8 % Speed: 77.0 km/h Temperature: 102.0�C Temperature: 32.0�C Absolute Pres.: 1010.0 mbar Voltage: 12.954 V Readiness: 0000 1100 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09D-927-750.clb Part No SW: 09D 927 750 FR HW: 09D 927 750 FR Component: AL 750 6A 0998 Revision: 00H64000 Serial number: Coding: 0000504 Shop #: WSC 31414 790 00001 VCID: 03053A0B4215119E0E-8056 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb Part No SW: 4L0 910 517 B HW: 4L0 614 517 D Component: ESP ALLRAD MK25E1 0010 Revision: 00H30001 Coding: 0087089 Shop #: WSC 27066 002 104857 VCID: 295948A380F92BCE64-807C 6 Faults Found: 01423 - Lateral Acceleration Sensor (G200) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 2 Fault Frequency: 1 Reset counter: 223 Mileage: 199292 km Time Indication: 0 Date: 2022.02.28 Time: 19:06:16 Freeze Frame: Count: 196 Count: 8515 Count: 325 Count: 49408 01542 - Yaw Rate Sensor (G202) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 2 Fault Frequency: 1 Reset counter: 223 Mileage: 199292 km Time Indication: 0 Date: 2022.02.28 Time: 19:06:16 Freeze Frame: Count: 196 Count: 8515 Count: 324 Count: 49408 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 183 Mileage: 199305 km Time Indication: 0 Date: 2022.03.01 Time: 07:35:41 Freeze Frame: Count: 192 Count: 8513 Count: 128 Count: 37632 01486 - System Function Test Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:22 Freeze Frame: Count: 128 Count: 8513 Count: 320 Count: 47872 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:22 Freeze Frame: Count: 128 Count: 8513 Count: 8215 Count: 47872 01487 - System Function Test 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 3 Reset counter: 183 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 17:41:02 Freeze Frame: Count: 2368 Count: 8513 Count: 321 Count: 46848 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H31 0220 Revision: 31050601 Serial number: 10601100783298 Coding: 0000007 Shop #: WSC 31414 790 00001 VCID: 63C51A8BA255B19E6E-8036 Subsystem 1 - Part No: 4F0 910 131 C Component: FBSAUDIC6 EZS H45 0080 Subsystem 2 - Part No: 4F0 910 335 Component: FBSAUDIC6 KSG H27 0080 Subsystem 3 - Part No: 4F0 910 220 F Component: FBSAUDIC6 IDG H01 0060 No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Cannot be reached ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb Part No SW: 4L1 910 732 H HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 387E 077552188 Coding: 0002003 Shop #: WSC 00000 000 08192 VCID: 2F6DA6BBBE1D45FEBA-807A Subsystem 1 - Part No: 4L0 910 609 Component: E0380 BedienteilH01 0060 Subsystem 2 - Serial number: 00000000765044 Subsystem 3 - Serial number: 0121.05.070000000100011565� Subsystem 4 - Serial number: 011565� 2 Faults Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:21 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 17:40:02 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4L0 910 043 HW: 4L0 820 043 E Component: KLIMABETAETIGUNGH05 0060 Revision: 00---012 Serial number: 00000030046534 Coding: 0655400 Shop #: WSC 31414 790 00001 VCID: 61C91083B849A38E7C-8034 4 Faults Found: 02874 - Control Module 2 for Central Convenience (J773) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:27 Freeze Frame: ON 02508 - Temperature Sensor for Refrigerant (G454) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:27 01087 - Basic Setting Not Performed 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 177 Mileage: 198975 km Time Indication: 0 Date: 2022.02.20 Time: 16:13:14 02379 - Positioning Motor for Left Side Vent (V299) 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 3 Fault Frequency: 6 Reset counter: 185 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:28 Freeze Frame: Voltage: 13.30 V Temperature: 30.0�C (no units): 195.0 (no units): 81.0 Temperature: 24.0�C ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 K HW: 4F0 907 279 Component: ILM Fahrer H17 0240 Revision: 00000000 Serial number: 4F0907279 Coding: 0013122 Shop #: WSC 31414 790 00001 VCID: 3169A0C3A829530EAC-8064 Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AU716 H13 0080 Coding: 00008178 Shop #: WSC 31414 Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH13 0090 Coding: 01788459 Shop #: WSC 31414 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4L0 910 110 B HW: 4L0 035 110 Component: MP3-Changer H43 0390 Revision: 00043000 Serial number: AUZ5ZBG1066066 Shop #: WSC 00000 000 00000 VCID: 1E336B7FC9B7DC7601-804A No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Cannot be reached ------------------------------------------------------------------------------- Address 14: Susp. Elect. Cannot be reached ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4L0-910-655.lbl Part No SW: 4L0 910 655 D HW: 4L0 959 655 C Component: 70 AIRBAG AUDI8RH42 0230 Revision: 03H42000 Serial number: 00399D0334KL Coding: 0014128 Shop #: WSC 31414 790 00001 VCID: 2E53BBBFB9174CF6B1-807A Subsystem 1 - Serial number: 6332QSME2F5B325FX Subsystem 2 - Serial number: 6342QSME2F5B3D31T Subsystem 3 - Serial number: 6352QSME2F184F0BX Subsystem 4 - Serial number: 6362QSME2B19454BP Subsystem 5 - Serial number: 63734SME29331A4B1 Subsystem 6 - Serial number: 63834SME29331F451 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenks�ulenmodul H08 0230 Revision: 00H08000 Serial number: 90054071230229 Coding: 0012142 Shop #: WSC 31414 790 00001 VCID: 66C3039F5167C4B689-8032 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H02 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4L0-910-xxx-17.lbl Part No SW: 4F0 910 930 C HW: 4L0 920 930 S Component: KOMBIINSTR. M73 H21 0220 Revision: 00600000 Serial number: 6EH31GZ57 Coding: 2657643 Shop #: WSC 27066 002 104857 VCID: 23455A8BE2D5F19E2E-8076 No fault code found. ------------------------------------------------------------------------------- Address 18: Aux. Heat Cannot be reached ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4L0-910-468.clb Part No SW: 4L0 910 468 A HW: 4L0 907 468 B Component: J533__Gateway H06 0060 Revision: 00H06000 Serial number: 1100B0751981FD Coding: FDFFFF7FF8FFF70F Shop #: WSC 00003 329 88140 VCID: 2D51BCB3B41137EE88-8078 20 Faults Found: 03158 - Control Module for Information Electronics 1 (J794) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 1 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:58:22 03163 - Control Module for Information Electronics 2 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 1 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:58:22 00380 - Special Vehicle Control Module (J608) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:23 00471 - Control Module for Elect. Regulated Dampers (J250) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:23 01207 - Control Module for Auxiliary Heater (J364) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:24 00461 - Control Module for Seat Memory; Passenger (J521) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:27 01325 - Control Module for Tire Pressure Monitoring (J502) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:27 02003 - Driver Identification Control Module (J589) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:27 00462 - Control Module for Seat Memory; Rear (J522) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:27 03109 - Tire Pressure Monitoring Control Module 2 (J793) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:27 00465 - Control Module for Telephone/Telematic (J526) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:27 00460 - Control Module for Display and Input; Rear (J524) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:58:22 02077 - Media Player Position 2 (R119) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:58:22 02078 - Media Player Position 3 (R120) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:58:22 02079 - Media Player Position 4 (R121) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:58:22 00467 - TV Tuner (R78) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:58:22 02230 - Digital Radio (DAB) (R147) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:58:22 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:58:22 01301 - Control Module for Voice Recognition (J507) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:58:22 02075 - Rear Right Information Display Control Head Control Module (J649) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:58:22 ------------------------------------------------------------------------------- Address 1D: Driver Ident. Cannot be reached ------------------------------------------------------------------------------- Address 1E: Media Player 2 Cannot be reached ------------------------------------------------------------------------------- Address 20: High Beam Assist. Cannot be reached ------------------------------------------------------------------------------- Address 27: Ctrl Head, Rear Cannot be reached ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4L0 910 158 HW: 4L0 919 158 C Component: KLIMABETAETIGUNGH05 0060 Revision: 00---009 Serial number: 00000030046737 Coding: 0000006 Shop #: WSC 31414 790 00001 VCID: 68DF0DA75B73D2C6BB-803C 3 Faults Found: 00003 - Control Module 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 2 Fault Frequency: 8 Reset counter: 185 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:27 01320 - Control Module for Climatronic (J255) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:27 Freeze Frame: ON 02874 - Control Module 2 for Central Convenience (J773) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:27 Freeze Frame: ON ------------------------------------------------------------------------------- Address 2E: Media Player 3 Cannot be reached ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4L0-910-553.lbl Part No SW: 4L0 910 553 C HW: 4L0 907 553 Component: LUFTFDR.-CDC H03 7660 Revision: --H03001 Serial number: 15.1528-0096.2 Coding: 0015510 Shop #: WSC 51366 000 1048576 VCID: 2A5BB7AF85FF20D66D-807E 8 Faults Found: 01316 - ABS Control Module 013 - Check DTC Memory Freeze Frame: Fault Status: 11101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 185 Mileage: 199305 km Time Indication: 0 Date: 2022.03.03 Time: 15:59:40 Freeze Frame: Error Code: 98 00142 - Left Front Dampening Adjustment Valve (N336) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 11101100 Fault Priority: 3 Fault Frequency: 8 Reset counter: 185 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:25 Freeze Frame: Error Code: 210 00143 - Front Right Dampening Adjustment Valve (N337) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 11101100 Fault Priority: 3 Fault Frequency: 8 Reset counter: 185 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:25 Freeze Frame: Error Code: 213 00144 - Rear Left Dampening Adjustment Valve (N338) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 11101100 Fault Priority: 3 Fault Frequency: 8 Reset counter: 185 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:26 Freeze Frame: Error Code: 216 00145 - Rear Right Dampening Adjustment Valve (N339) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 11101100 Fault Priority: 3 Fault Frequency: 8 Reset counter: 185 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:26 Freeze Frame: Error Code: 219 01583 - Leak in System Detected 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 224 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 17:39:33 Freeze Frame: Error Code: 70 01400 - Suspension Level Control 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 3 Reset counter: 223 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 17:41:16 Freeze Frame: Error Code: 66 01769 - Sensor for Vehicle Leveling; Front Right (G289) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 225 Mileage: 0 km Time Indication: 0 Freeze Frame: Error Code: 27 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Cannot be reached ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 887 T HW: 4E0 919 887 M Component: MNS ECE H49 1030 Revision: 00000000 Serial number: 399E1077576464 Shop #: WSC 27066 002 1048576 VCID: 3E738BFF6977BC7621-806A 1 Fault Found: 02444 - Disk Drive Load / Eject Malfunction 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 38 Reset counter: 185 Mileage: 199202 km Time Indication: 0 Date: 2022.02.26 Time: 22:45:29 ------------------------------------------------------------------------------- Address 3D: Special Function Cannot be reached ------------------------------------------------------------------------------- Address 3E: Media Player 4 Cannot be reached ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl Part No SW: 4L0 910 793 B HW: 4L0 959 793 B Component: TSG FA H12 0150 Revision: 00-00000 Coding: 0064207 Shop #: WSC 31414 790 00001 VCID: 2F6DA6BBBE1D45FEBA-807A 2 Faults Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:22 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 11 Reset counter: 185 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:22 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4L0-910-289.lbl Part No SW: 4L0 910 289 F HW: 4L0 907 289 C Component: Komfortgeraet H07 0040 Revision: 0040 --- Serial number: 01045048110000 Coding: 7616767 Shop #: WSC 31414 790 00001 VCID: 3365AACB5235611EDE-8066 Subsystem 1 - Component: Sounder No Answer Subsystem 2 - Component: IRUE No Answer 5 Faults Found: 01403 - Glass-Break Sensors; Rear 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 254 Reset counter: 185 Mileage: 198241 km Time Indication: 0 Date: 2022.01.11 Time: 20:40:47 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 185 Mileage: 198241 km Time Indication: 0 Date: 2022.01.11 Time: 20:40:49 03073 - Rear Lid Closed Sensor 1 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 5 Fault Frequency: 3 Reset counter: 225 Mileage: 199305 km Time Indication: 0 Date: 2022.03.01 Time: 15:45:06 01135 - Interior Monitoring Sensors 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 185 Mileage: 198340 km Time Indication: 0 Date: 2022.01.14 Time: 17:49:39 02103 - Control Module 2 for Vehicle Electrical System (J520) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 3 Fault Frequency: 112 Reset counter: 162 Mileage: 198340 km Time Indication: 0 Date: 2022.01.14 Time: 18:56:47 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: Redir Fail! Part No SW: 4L0 910 223 K HW: 4L0 035 223 C Component: DSP-AU716-RD H07 0270 Revision: 06S00000 Coding: 060000 Shop #: WSC 31414 790 00001 VCID: 2C57B1B74F0B3EE69F-8078 No fault code found. ------------------------------------------------------------------------------- Address 4C: Tire Pressure II Cannot be reached ------------------------------------------------------------------------------- Address 4E: Ctrl Head RR Cannot be reached ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 Component: ILM Beifahrer H12 0100 Revision: Serial number: 00000000226676 Coding: 0001001 Shop #: WSC 31414 790 00001 VCID: 5EB32B7F89379C7641-800A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl Part No SW: 4L0 910 793 B HW: 4L0 959 792 B Component: TSG BF H12 0150 Revision: 00-00000 Coding: 0064206 Shop #: WSC 31414 790 00001 VCID: 2F6DA6BBBE1D45FEBA-807A 2 Faults Found: 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 11 Reset counter: 185 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:22 02115 - Locking Unit for Central Locking 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 11 Reset counter: 185 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:22 ------------------------------------------------------------------------------- Address 53: Parking Brake Cannot be reached ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 F Component: Dynamische LWR H02 0010 Revision: 00000001 Serial number: Coding: 0000008 Shop #: WSC 31414 790 00001 VCID: 3D718CF36471A76E38-8068 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 S Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 388E$077627176 Coding: 0000001 Shop #: WSC 31414 790 00001 VCID: 3169A0C3A829530EAC-8064 2 Faults Found: 00856 - Radio Antenna 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 5 Fault Frequency: 1 Reset counter: 225 Mileage: 199305 km Time Indication: 0 Date: 2022.03.01 Time: 16:13:04 00856 - Radio Antenna 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 11 Reset counter: 185 Mileage: 198831 km Time Indication: 0 Date: 2022.02.17 Time: 19:14:58 ------------------------------------------------------------------------------- Address 57: TV Tuner Cannot be reached ------------------------------------------------------------------------------- Address 5E: Ctrl Head LR Cannot be reached ------------------------------------------------------------------------------- Address 5F: Information Electr. Cannot be reached ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4L0 910 181 A HW: 4L0 915 181 Component: J0644 BEM H12 0690 Revision: -------- Serial number: 00000000003689 Shop #: WSC 74500 745 89398 VCID: 25414493ECE10FAE40-8070 Subsystem 1 - Part No: 4F0 915 105 D Component: von VA0 2706012203 Coding: 344630393135313035442056413032373036303132323033 Shop #: WSC 31414 790 00001 1 Fault Found: 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 3 Reset counter: 225 Mileage: 199305 km Time Indication: 0 Date: 2022.03.01 Time: 01:54:45 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4L0-910-795.lbl Part No SW: 4L0 910 795 B HW: 4L0 959 795 B Component: TSG HL H21 0050 Coding: 0016394 Shop #: WSC 31414 790 00001 VCID: 3169A0C3A829530EAC-8064 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Cannot be reached ------------------------------------------------------------------------------- Address 66: Seat, Rear Cannot be reached ------------------------------------------------------------------------------- Address 67: Voice Control Cannot be reached ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4L0-910-441.clb Part No SW: 4L0 910 441 A HW: 4L0 907 441 A Component: J772__Rearview 0050 Revision: --H12--- Serial number: 525PA8-J7442VD Coding: 1021001 Shop #: WSC 31414 790 00001 VCID: 24475997E7DBF6A657-8070 1 Fault Found: 03006 - Back-up Camera System not calibrated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 182 Time Indication: 0 Freeze Frame: Invalid Invalid Invalid ------------------------------------------------------------------------------- Address 6D: Trunk Elect. Labels: 4L0-910-945.clb Part No SW: 4L0 910 945 HW: 4L0 827 851 B Component: ValeoHeckdeckel H21 0280 Revision: --H21001 Serial number: E5030000B Shop #: WSC 98765 666 38354 VCID: 6CD771B74F8BFEE6DF-8038 Subsystem 1 - Part No: 4L0 910 946 Component: ValeoHeckdeckel H21 0280 Subsystem 2 - Serial number: E5030100B Subsystem 3 - Serial number: RD01.06.07--H21001001A0021� Subsystem 4 - Serial number: 1A0021� No fault code found. ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl Part No SW: 4L0 910 290 A HW: 4L0 907 290 A Component: ILM HINTEN 2 H05 0060 Revision: AAH05061 Serial number: 002808336----- Coding: 0003843 Shop #: WSC 31414 790 00001 VCID: 2643439F91E704B649-8072 Subsystem 1 - Part No: 4L0 910 591 Component: J_245_EE15_SKB09H10 0180 Subsystem 2 - Part No: 4L0 910 591 Component: J_394_EE15_SKB09H10 0180 Subsystem 3 - Part No: 4L0 910 591 Component: J_392_EE15_SKB09H10 0180 2 Faults Found: 01512 - Control Module for Sliding Roof 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 12 Reset counter: 185 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:22 02907 - Control Module for Roof Shade (J394) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 12 Reset counter: 185 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 15:57:22 ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4L0-910-795.lbl Part No SW: 4L0 910 795 B HW: 4L0 959 794 B Component: TSG HR H21 0150 Coding: 0016394 Shop #: WSC 31414 790 00001 VCID: 3169A0C3A829530EAC-8064 No fault code found. ------------------------------------------------------------------------------- Address 75: Telematics Cannot be reached ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4F0 910 283 H HW: 4F0 919 283 H Component: Parkhilfe 8-Kan H12 0080 Revision: 00H12000 Serial number: 06320713500075 Coding: 0221146 Shop #: WSC 31414 790 00001 VCID: 295948A380F92BCE64-807C 1 Fault Found: 01629 - Sensor for Parking-Aid; Front Left (G255) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 182 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 17:39:56 ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached ------------------------------------------------------------------------------- Address 7F: Inform. Electr. II Cannot be reached End-------------------------(Elapsed Time: 05:24)--------------------------
Lots of faults that all seem voltage related, these cars are very sensitive to battery voltage.
Is your battery new, and if so was it coded to the car correctly with VCDS or a dealer?
Start with clearing all the codes, it is best to click into each module and clear them there rather than doing a mass clear.
The ones that immediately come back are the prime suspects. Start with any that say open short or open circuit, those are the ones drawing power.
AFTER I CHANGED VARIABLE SOLENOID VALVE FOR BANK 1 I RE-SCAN MY ENGINE AND I FOUND:
Code:
Address 01: Engine Labels:. 079-907-560-BAR.clb Part No SW: 4L0 910 560 H HW: 4L0 907 560 A Component: 4.2l V8/4V 0020 Revision: 71H21--- Serial number: Coding: 01210010190F0560 Shop #: WSC 31414 790 00001 VCID: 2D51BCB3B41137EE88-8078 4 Faults Found: 005241 - Brake Boost Vacuum System P1479 - 008 - Mechanical Failure Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 17:40:22 Freeze Frame: RPM: 1759 /min Load: 57.6 % Speed: 17.0 km/h Temperature: 63.0�C Temperature: 41.0�C Absolute Pres.: 1020.0 mbar Voltage: 13.335 V 000768 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 17:41:30 Freeze Frame: RPM: 661 /min Load: 30.2 % Speed: 0.0 km/h Temperature: 54.0�C Temperature: 20.0�C Absolute Pres.: 1020.0 mbar Voltage: 13.335 V 000769 - Cylinder 3 P0303 - 001 - Misfire Detected - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 255 Mileage: 199260 km Time Indication: 0 Date: 2022.02.28 Time: 17:41:30 Freeze Frame: RPM: 661 /min Load: 30.2 % Speed: 0.0 km/h Temperature: 54.0�C Temperature: 20.0�C Absolute Pres.: 1020.0 mbar Voltage: 13.335 V 004952 - Cylinder 3 Ignition Circuit P1361 - 004 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 199282 km Time Indication: 0 Date: 2022.02.28 Time: 18:10:42 Freeze Frame: RPM: 2828 /min Load: 89.8 % Speed: 77.0 km/h Temperature: 102.0�C Temperature: 32.0�C Absolute Pres.: 1010.0 mbar Voltage: 12.954 V Readiness: 0000 1100
005241 - Brake Boost Vacuum System: First check to see if the vacuum pump has power, and determine that it operates and generates vacuum. If it does, then start looking for a vacuum leak somewhere. If there is a vacuum leak it could result in the random / intermittent misfires you are experiencing.
004952 - Cylinder 3 Ignition Circuit / P1361 - 004 - Open Circuit - Intermittent: Possibly a bad ignition coil. You could swap the coil with another cylinder and see if the problem follows, if it does....replace the ignition coil.
zied012 (03-20-2022)
I checked the vacuum pump and it works fine, and I need to check where the vacuum leaks are in the circuit.
for cylinder 3, I swapped the ignition coil to cylinder 6 and the fault does not follow, so I swapped the spark plug and the fault does not follow. the fault occurred after starting and above 3000 rpm and sometimes from idle, and when I erased it, it came back instantly.
P1361 Cylinder #3 ignition "open circuit - intermittent" - make sure there are no wire harness / electrical connector issues. If you find a vacuum leak somewhere, fixing that may also fix the "random multiple mis-fires".
I checked all connectors and there is no wire harness yet, and the fault sometime came sometime no, and when it came, it cause a miss-fire and EPC lamp came ON.
cyrus89
29
03-24-2015 12:34 PM
