VCDS TPMS ENABLING Q7?
HI, I HAVE 2011 model Q7, and a fully activated vag cable, is there a way of getting tyre pressure monitoring system enabled by vcds?
I've read some but they werent for the Q7.
I'm keen to know the same. Mine has no MMI settings for it present. I assume after I get the sensors we'll need to enable it in the ECU to then be visible in MMI.
The 2010 Q7 does not use tire pressure sensors. It uses differentiation in the wheel spin from the ABS rotors. In mine, it's activated in the MMI.
One needs to verify that their ABS pump can support this functionality. (I don't know how to do that on Audi.)
Well, I just walked outside and sure enough...plain old rubber valve stems which means that you are right! No sensors in the wheels!
So it should be very inexpensive to "add" this feature via VCDS if you do not already have it. No need to buy sensors.
bballfreak
9
04-14-2019 06:59 PM
iamdrewseph
10-01-2015 11:33 AM
