water accumulation in driver's side door
Has anyone noticed a decent amount of water that accumulates in the door after it rains? When i wash the car there is some water that collects and drips down when you open the door just below the weather stripping i believe. after Irene, a good 1/2 gallon poured down..thoughts?
I had the same thing after Irene on the rear passenger side. To be clear, the carpet inside is bone dry, but it seems to accumulate on the sill between the weather strip seal and the outside door edge. Weird.
Interesting. Mine never had this issue UNTIL it was hit on the passenger rear and repaired. Now that door only will accumulate water in a storm. No water inside as you said. Just falls to the ground when it is opened. I figured the door just needed adjusting.
Same here. Also noticed that the rear passenger door always seems to accumulate more dirt and grime than the other 3 doors. And before someone asks all 4 doors are used almost every day due to me having two kids
i also didnt have any problems until i hit the rear passenger door then repaired new door now after it rains water accumulates nothing on the floor until i open the door just falls to the ground. You mentioned the door needed adjustment. Did you adjusted the door? Did it.work?
this is driving me crazy lol. Please let me know. Thanks.
theodore
09-28-2010 04:24 PM
Quimbola
09-12-2008 10:51 AM
RafRaf
05-22-2003 09:04 AM
