What the Heck!?! Q7 Needs a Hard Reset Button
Ok, I jump in my Q7 and press the start button, nothing happens. Try again, nothing. verify key is on me, yep. Notice the dash has the EPC, traction control, and ABS lights on. Odd. Nothing else is on. So, I try the key in the ignition, nothing, except it is now stuck in there. Go to get the manual to verify how to jump it or see if I can pull some fuses to try and force a reset. Well, see, glove box is power released and it won't release. Great. So there it sits in my driveway. Where is the reset button when you need it.
Anyone want to tell me how to hook up a charger to save the battery at least?
I realized after posting my message that I had jumped in the car this morning but then got called away by someone. I must have hit the start button but did not actually start the car. It must work like turning the ignition key to ON. I never came back until tonight so it must have drained the battery. I would have thought that if you left with the advanced key that the car would shut off after a short period of time, apparently it does not. After i figured out where the terminals where I was able to at least get enough juice into the car to turn the car off and get the key out. I will fast charge the battery a while and see if I can get her started.
Although I have read otherwise, I do not believe there is any battery run down protection on the Q7.
My Q has done this twice, both times were cured with 30 min on the charger.
Overnight trickle charge did the trick. Man, I have to say that this tech laden car turns into one hell of a paperweight when the battery runs down. Can't open the hatch, can't get the key out, can't even open the glove box. I never thought about all the implications of a power everything vehicle like the Q7, until now.
If you leave any interior lights on, you'll find that the car will automatically shut them off after a period of time.
research suggests more/worse crash injuries caused by latch mechanism. Smooth facia even when bust open is better. Prolly a good trade off against dead battery risk.
I think you are the first one to post about that battery killer... good work.
The front tronk lid is electrically powered so when the car dies you have to put a jumper on the fuse panel to get the trunk lid open to get to the battery. Absolutely STUPID design. Always make the battery accessible without electric power... Sometimes I wonder about German designers.
I was under the impression that there was battery protection. I remember reading in the manual, that it turns off everything unused n order to make sure that the battery has enough just for at last the next start.
Also longterm storage turns off many things also.
I read on this site that it is under the driver seat. I skimmed through the US Audi manual but could not find any instructions on how you get to that bad boy. Is there some special release to lift up the driver seat? Please don't tell me I have to unbolt the seat or something idiotic like that?!?
