Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
What the Heck!?! Q7 Needs a Hard Reset Button
Old 06-20-2008, 02:55 AM
  #11
AutoUnionQ7's Avatar
Call the Dealer ASAP or call Roadside assistance. Probably the advanced key system is panicing
Old 06-20-2008, 02:57 AM
  #12
Default that does sound stupid. Probably the reason, why when I went to open
up a 911 Turbo at the Audi/VW/Porche/Mazda dealer, it was completely dead, and the switches were working. But the interior was great!
Old 06-20-2008, 02:59 AM
  #13
But if the key is in ignition, then batt. protection ceases to exist
Old 06-20-2008, 05:37 AM
  #14
Jusforfun's Avatar
Default You can see it from outside...
but I have never accessed it. mksap11 is the man for that kind of info.
Old 06-20-2008, 05:55 AM
  #15
Jusforfun's Avatar
Default There have been a couple of cases where it failed 4LO-910-181 plus TSB...
Ask your service about:
- Battery manager 4LO-910-181
- TSB 91-07-13<ul><li><a href="https://forums.audiworld.com/q7/msgs/22454.phtml">https://forums.audiworld.com/q7/msgs/22454.phtml</a</li></ul>
Old 06-20-2008, 05:56 AM
  #16
Jusforfun's Avatar
My reply below to V6 TDI was meant for your consideration :-)
Old 06-20-2008, 06:50 AM
  #17
mksap11's Avatar
Default If your svc mgr can't find it, ask him/her about TSB "2014127/1" (same thing, different name)
Note that this TSB only applies to 2007s with VIN up to 7D063347 and involves updating the MMI with a later version (i.e. firmware update)
Old 06-20-2008, 06:52 AM
  #18
mksap11's Avatar
You need to remove the driver's seat in order to remove/install the battery
Old 06-20-2008, 05:38 PM
  #19
jesjammin's Avatar
Default Read my post more closely...
the only reason the key was in there was because the start button would not work so I tried the key. Of course with not power once you insert it you can't get it back out.
Old 06-20-2008, 05:48 PM
  #20
jesjammin's Avatar
Default Re: If your svc mgr can't find it, ask him/her about TSB "2014127/1" (same thing, different name)
I am going to hold off on pushing the TSB with my dealer for now. I have a hunch there is a software bug involving the start button. I have noticed a slight delay which varies in length between when you press the start button and when the ignition fires. In my dead battery case I know I was about to start the car; I recall pushing in on the brake and pressing the start button. However, I released the start button before the car started to turn over because someone pulled in my driveway behind me. My hunch is that the act of releasing the start button just before the ignition engages may put the car in a weird state. As an ex software guy I smell an untrapped condition.
I am tempted to experiment with my hunch if a i can find a few hours to kill. I'll let you all know if I try it out.
Quick Reply: What the Heck!?! Q7 Needs a Hard Reset Button
