2017 Q7 prestige burning oil, 500 miles/quart
Just got a 2017 Q7 recently. I have changed the engine oil (CSTRL EDGE 5W-40) and filter by myself. Monitoring the oil consumption now. I have driven 100 miles and I believe it will cost 1 quart in 500 miles.
No smoke, and no leak ( I did not see it so far.) I tested PCV by pulling the engine oil cap out, I can feel the suction and the engine stopped. no weird sound.
So any advice on what is the next step? Maybe engine flush will be the next step?
I'm sorry that you have the burning oil problem, but its a common problem. If you live close to an Audi dealer, might be able to get it topped off for free. Mine does that.
Here's the thread on the issue you're having....
https://www.audiworld.com/forums/q7-...-year-3024173/
The following 2 users liked this post by ecbc1:
CrazyEights (07-25-2023),
lhhnick (03-01-2023)
The only thing that may slow it down is new pistons and rings. Better bet would be to trade for different vehicle.
Thanks, it is126000 miles now, I just got this car and want to use it to improve my handy skill. So not ready yet for the new pistons or trade new car lol
Same problem as yours on a 2017 Q7 but at 81k miles. Literally about to go get a qt of oil to top up. I had the diagnostics done on the car from the Audi dealership and they didn't find any leaks or problems. Service manager said you might have to replace the engine lol and it costs 13-15k. Any help would be appreciated
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
I have done some extensive research on the matter and the most cost efficient and easy way out of this oil consumption issue is to use local transit or take up cycling. This may be something I have to endure in the future if the car isnt paid off and the engine ends up failing.
Just DON'T SUDDENLY FLOOR THE GAS PEDAL in any circumstances or avoid doing so as much as possible. Catastrophic failure occurs after it was floored in many cases and especially in my case. However some people reported the failure occurred without them flooring it. Check here what's happening to 28+ others with the same issue: https://www.audiworld.com/forums/q7-...024173/page42/
These engines fail following a history of increasing oil consumption. The cylinders lose compression and the car loses power and consumes excessive amounts of oil. There are reports of broken pistons, broken valves and cracked cylinder heads as people kept using the cars like that. This is the result of excessive crankcase pressure caused by lost compression in cylinders, coupled with lighter build materials (pistons, rings, valves, etc.) for easy engine power.
Of course there are exceptions but it seems the majority of owners past 60,000 miles are having this issue. I have done some research online for used cars (A6, A7, Q7) with this exact same engine and have checked their CARFAX reports. A lot of them were auctioned or suddenly listed for sale after repeated oil changes or spark plug replacements which hides this very issue.
pschall
Q5/SQ5 MKI (8R) Discussion
12
08-31-2020 09:26 AM
a4natsfan
A4 (B9 Platform) Discussion
08-29-2018 02:40 PM
Zfoot
2.0T FSI Discussion
08-15-2017 05:44 AM
BobT(nolonger)A6
06-03-2001 08:41 AM
bluesman
14
09-08-2000 09:38 PM
