2019 3.0T hp change
2019 3.0T hp change
Just check 2019 sepcs.
Audi change 3.0T to 55 TFSI.
They are the same supercharger engine but HP is 329.
I remembered it was 333 HP last year.
I am surprising it tuned down the power instead of increasing it.
It seems like car manufacturers are taking the cue from the government. What's the point of comparing HP numbers if they changed based on arbitrary way of calculating it. Same with fuel economy or adjusted cost of living .... We should just have following designations for the cars - it goes: put,put,put, or wroom, or swish, or weeeeeeee........
I believe it had to due with the emissions issue...leaner mixture = less hp, in forced induction engines a richer mixture helps prevent potential engine damage as the hp is increased via higher boost pressure etc
From Audi:
Starting with 2019 MY, rated horsepower will be derived from a single, global kilowatt (kW) metric, confirmed by an SAE horsepower test. All driving and performance characteristics such as fuel economy and 0-60 times remain the same as prior Model Year
Refer to post #4.
From Audi:
From Audi:
tigerhonaker
Audi A3 / S3 / RS 3 MKII
231
01-05-2021 08:21 AM
RJC 1
Q7 MKII Discussion
36
02-10-2019 06:38 PM
