Adaptive Suspension Question
I recently purchased a Q7 and have read through the manual but still can't figure out what the ride height of the air suspension is when the vehicle is off. I think it defaults to whatever you had set previously once the car is started but does it stay that height when turned off or does it lower for easy entry/exit?
Asking because we have a new baby and it would be nice if the air suspension automatically lowered to lowest setting when you turn the car off.
Also, you'd really want it to lower to the "rear loading" position, which is lower than any driving position. I suppose some clever person could tap into the rear lowering switch in the back and make a parallel switch near the driver which you could then activate after shutting down but before opening any doors. Hmmm, I may look into that.
Automatic lowering would be a little problematic for this reason: the car will never lower if there's a door open. This is to prevent an open door from hitting a curb, etc. So even it if were programmed to automatically lower, you would have to remember to hold off opening any doors until the lowering was complete.
https://www.active-sound.eu/en/audi/...air-suspension
will be looking into this module when my Q7 comes this summer. I don't know too much about the company but i have seen some C7 vehicles running the same module with success.
edit:
looks like on some models you might have to pin some wires, not as bad as cutting a factory harness.
"This is a Do-it yourself solution, the original harness will be cut trough and the new conduction will be soldered on"
