Apple CarPlay interrupting radio
Starting a few months ago, my FM radio was constantly interrupted by CarPlay. Every time I switch to radio, within a few minutes, radio will stop, and MMI will show CarPlay interface. It was so bad, I had to disconnect the lighting cable if I want to listen to FM radio.
Anyone notice the same problem?
BTW, I have a 2016 q7 prestige. Located in US.
Thanks. I have two iphones experiencing the same problem, so I will start with changing the lighting cable, and maybe different USB port on Q7.
Is anyone using the phone?
If someone is on a webpage (or FB, Instagram, whatever) and an audio file attempts playing, it will interrupt it and switch to CarPlay. Even scrolling past a video that has audio embedded will do it.
No. There was no notification either.
I thought this has something to do with iOS updates. Both phones are on latest 11.4.1.
I changed lighting cable, and different USB port under armrest. Still having problem.
Did you try to use a toothpick to clean up the lightning port on the iPhone? The dirt/lint in the port could cause random connect/disconnect issues.
I also had another 2018 A3, and same iPhone is working without any interruption. Very strange.
Update:
It is also happening with 2018 A3.
After updating to iOS12 on both iPhones, so far this problem is gone for both Q7 and A3. Hopefully it stays like this.
Limey Chris
02-18-2003 08:43 AM
