When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Adjusted the vertical dealignment from 1.7 to -.1 and the code is gone and cruise features are back
used obdeleven live data via module 13
3 items to look at are
misalignment horz
misalignment horz fast algorithm
all need to be between -.8 to .8
top left screw if you are looking at it is for vertical. I had to turn mine clockwise 4.5 times to go from 1.7 to -.10
The bottom right is for horizontal
if you simply had a bumper replacement, grill replacement this should work for you.
I had 20 people, 2 forums and 3 Facebook groups say I needed Odis with alignment and it couldn’t be done by me or anyone outside of audi. Audi wanted $1100
misalignment horz
went with my gut and it’s working now !
Coincidentally, I just bought a 2018 Q7 - Prestige and I drove off the lot not seeing the “presense limited” “acc limited” “distance warning limited”… anyhow, took them about a week to diagnose what was wrong. They needed to do an alignment that cost almost exactly 1k, but, was covered under warranty. I wonder if they could have simply did what you did to correct it. Either way, no more codes are being thrown up, for now
Twice in the past week I have had "Audi Presense rear limited...see owner's manual." Not sure what is causing this though I just wiped down all the sensors for good measure. The owner's manual was useless other than saying to take it to the dealer if the notice persists.
Nothing has happened to the vehicle (impact, etc.) to my knowledge. It mostly sits in my garage as I work from home.
I have obdeleven but am not sure if that is helpful in assessing the issue since I'm not a power user of that device.
