Audi Q7 2017 Oil Consumption. Any one else with this issue with this model and year?
Old 06-29-2024, 09:43 AM
  #991
Brimstone's Avatar
Originally Posted by Brimstone
Turns out my engine light was due to a bad crank case. A bit under $4k to repair. Ugh. Mechanic told me he's done it for a few cars and that has fixed oil consumption, he's seen a couple with bad pistons too. (unsure about the state of mine) plan is to watch the consumption once the new crank case is in.
Well the crank case did not fix the oil issue, the car seems to have lost its refinement at a minimum as well (power seemed ok, but it rumbled more and was still burning oil at about 1 qt per 500 miles for the last 4 or so quarts I put in) I decided to bite the bullet and after talking it over with the wife we decided we needed something bigger, so we traded it in for a Wagoneer L last week.
Do like the new ride, I miss the Audi in a few ways, although the size and utility for the new one can't be compared.
Audi was definitely more fun to drive on windy roads. I was hoping to keep it 2-3 more years, if I knew for sure that the engine would be reliable if I just put the oil in, I think I would have just kept doing so, but I did not want to end up with a repair which could exceed the value of the vehicle and I did not want to have an issue in an inconvenient location
Old 06-30-2024, 09:43 AM
  #992
kelisko's Avatar
My latest video below, updating my followers on my dream Audi having this problematic engine in it, telling them what's coming next and showing them how I drive the car with a misfiring engine. This forum thread is being very helpful!
Old 07-01-2024, 07:03 AM
  #993
2kwik4u's Avatar
Glad the thread is helpful, but this post, in general, isn't. Come on man, you were doing so good!
The following 2 users liked this post by 2kwik4u:
AudiAllTheWay (07-01-2024), keg97 (07-01-2024)
Old 07-01-2024, 07:20 AM
  #994
2kwik4u's Avatar
ere's an updated log for those keeping score at home: (new data in red).
  • 97,118mi - Changed and full - 2023-09-25
  • 99,616mi - added 1qt, light on - 2,498mi since last fill - 2023-10-17
  • 102,594mi - added 1qt, light on - 2,978mi since last fill - 2023-11-18
  • 103,604mi - added 1qt, light on - 1,010mi since last fill - 2023-12-07
  • 104,454mi - added 1qt, light on - 850mi since last fill - 7,336 since last change - 2023-12-24
2024 Data
  • 105,105mi - added 1qt, light on - 651mi since last fill - 7,987 since last change - 2024-01-03
    • 8,022mi on change
  • 105,140mi - Changed oil. 5W-40 Liqui-Moly, Fresh Filter - 2024-01-13
  • 107,534mi - added 1qt, light on - 2,394mi since last fill - 2,394 since last change - 2024-02-04
  • 108,928mi - Added 1qt, light on - 1,394mi since last fill - 3,788 since last change - 2024-02-25 (Castrol GTX "Euro" 5W-40 oil from AutoZone)
    • 5,422mi on change
  • 110,562mi - Changed oil, 5W-40 Castrol GTX "Euro" 5W-40, fresh filter - 1,634 since last fill - 5,422 since last change - 2024-03-09 (Light came on as I was pulling into the parts store)
  • 112,461mi - Added 1qt, light on - 1,899mi since last fill - 1,899 since last change - 2024-03-18 (Castrol GTX "Euro" 5W-40 oil from AutoZone)
  • 113,492mi - Added 1qt, light on - 1,031mi since last fill - 2,930 since last change - 2024-04-02 (Castrol GTX "Euro" 5W-40 oil from AutoZone)
  • 115,035mi - Added 1qt, light on - 1,543mi since last fill - 4,473 since last change - 2024-04-19 (Castrol GTX "Euro" 5W-40 oil from Napa) - Light wasn't on, but gauge was showing VERY low. Driving 550mi home to IN this afternoon, so filled ahead of the light.
    • 5,337mi on change
  • 115,899mi - Changed oil, 5W-40 Liqui-Moly, fresh filter - 864 since last fill - 5,337 since last change - 2024-05-02 (Light came on about 30mi prior to change)
  • 117,415mi - Added 1qt, light on - 1,516mi since last fill - 1,516 since last change - 2024-05-12 (Castrol GTX "Euro" 5W-40 oil from AutoZone)
  • 118,791mi - Added 1qt, light on - 1,376mi since last fill - 2,892 since last change - 2024-05-17 (Castrol GTX "Euro" 5W-40 oil from AutoZone)
  • 119,424mi - Added 1qt, light on - 633mi since last fill - 3,525 since last change - 2024-05-24 (Castrol GTX "Euro" 5W-40 oil from AutoZone)
  • 120,340mi - Added 1qt, light on - 916mi since last fill - 4,441 since last change - 2024-06-03 (Castrol GTX "Euro" 5W-40 oil from AutoZone)
  • 121,389mi - Added 1qt, light on - 1,049mi since last fill - 5,490 since last change - 2024-06-16 (Castrol GTX "Euro" 5W-40 oil from Advance Auto Parts)
    • 5,782mi on change
  • 121,681mi - Changed oil, 5W-40 Castrol GTX "Euro" 5W-40, fresh filter - 292 since last fill - 5,782 since last change - 2024-06-18 (Still showing max full since last addition)
  • 122,751mi - Added 1qt, light on - 1,070mi since last fill - 1,070 since last change - 2024-06-24 (Castrol GTX "Euro" 5W-40 oil from AutoZone)
  • 124,023mi - Added 1qt, light on - 1,272mi since last fill - 2,342 since last change - 2024-06-30 (Castrol GTX "Euro" 5W-40 oil from AutoZone) - Note.....Car is telling me now "Oil change due in 1900mi". Not sure when I reset that light last. Going to start tracking that too.
Survived the 2,240miles of towing. 0FsQ7 asked for a quart about 3/4 of the way down to FL, and then again just after pulling into the driveway once we got home to Buffalo. Overall it did pretty well. Averaged around 13mpg for the tow. Never dropped below 5th gear, even in the mountains of WV and PA. Had ambient temps over 100deg on Saturday when we were headed through FL, GA, SC, and NC. A/C, engine coolant, oil, and charge air temps all stayed inline despite the cruise being set around 75 most of the way. Did see the oil temp spike over 240deg on the climb out of NC into VA on the north side of Mt Airy. It's several miles of 5%+ grade, and I held the speed at 75. Probably could have slowed a little, but nothing else was indicating any issues. Was a weird feeling to spin the motor over 4k rpm, under load, for that amount of time. Had a scare about 200 miles from home yesterday. Got a "drivetrain malfunction" warning, and the car went into limp mode. Pulled off on the shoulder and got the code reader out. Pulled a misfires codes for #4 and #6. Recorded those, then cleared them. Turned the car off for ~2min, then restarted. Codes didn't come back, and we towed the remaining distance home without issue. Not sure what happened there. Maybe a piece of carbon gave up and got blown out? Maybe it was a fluke? Who knows. Scared the wife enough I've been told to start shopping for a replacement. Outside chance we never figure the issue, or the fix, out on this particular vehicle. Which is a shame because of all this data!
Here's the new graph. Last 4 quarts have averaged over 1k mi per quart. Trend line has flattened somewhat. (**EDIT**, new graph. Realized the last one had data cut off. Also added a tighter grid for better visualization)
Here's the MPG log from the trip if anyone is interested
keg97 (07-01-2024)
Old 07-01-2024, 09:21 AM
  #995
kelisko's Avatar
https://www.youtube.com/watch?v=4ZL56FxbAYQ
It's probably not helpful to you but I think it is helpful to people who just found this lengthy thread and can't read through the thousand posts. I made a good summary and pointed out the issue with the potential remedies. No regret in that regard and I will do so again in the future if I have news.
Old 07-01-2024, 09:28 AM
  #996
kelisko's Avatar
2024 Data
    • 8,022mi on change
    • 5,422mi on change
    • 5,337mi on change
    • 5,782mi on change
This however I don't find useful and I consider spamming. We already know that the oil consumption will not improve and will keep getting worse. We also know that the rate of oil consumption can be affected by the age of the oil, the driving style and the environment factors. Many members reported the same thing without the lengthy repeated oil consumption data with one new line added each time. If I were you, I would post a thread just for that because you are spamming this one.
Old 07-01-2024, 09:47 AM
  #997
AudiQ72017CREC's Avatar
@kelisko Stop whining! Better to have data and graphs than just bla bla bla from you.
The following 3 users liked this post by AudiQ72017CREC:
AudiAllTheWay (07-01-2024), keg97 (07-01-2024), MoInEd (07-01-2024)
Old 07-01-2024, 11:03 AM
  #998
kelisko's Avatar
@AudiQ72017CREC Stop crying! Repeated data over and over with only minor additions is called SPAMMING!
Old 07-01-2024, 12:01 PM
  #999
2kwik4u's Avatar
No, it's not. Data collection and sharing is the basis for understanding the severity of a problem and the effectiveness of a remedy to that problem.
Continuously coming into a forum, about a vehicle you don't own, and only have an ancillary attachment to, to continue to promote your message, is quite literally, the definition of spamming; only slightly reworded. I googled the definition for you just to be clear.
The following 4 users liked this post by 2kwik4u:
AudiAllTheWay (07-01-2024), keg97 (07-01-2024), KnappAttack (07-02-2024), MoInEd (07-01-2024)
Old 07-01-2024, 12:12 PM
  #1000
kelisko's Avatar
Copying and pasting is spamming which is exactly what you have been doing, and which I definitely am not doing. Having the same opinion and expressing it in different ways on different occasions and in different contexts is not called spamming, sorry. English is a third language to me but I know that. Let's spare this thread of these unrelated back and forth exchanges, shall we? Just let everyone express their opinions. I have been annoyed with your repeated data which I initially found useful but did not bother you or anyone else with that. Don't mess with what I have to say or share and we'll be good.
Quick Reply: Audi Q7 2017 Oil Consumption. Any one else with this issue with this model and year?
