Audi Q7 2017 Oil Consumption. Any one else with this issue with this model and year?
#681
#683
#684
What I noticed when I used Liqui-moly engine flush is that there is apparently no sludge on engine components that are lubricated by the engine oil. I poured in new oil and installed a new oil filter before adding the Liqui-Moly solution. After running the engine for 15 or so minutes, the oil came out relatively clear enough and the filter looked fine. I proceeded to a second flush with fresh oil and filter again right after the first one and the oil came out even clearer. This makes me think that engine flush will do nothing to this problem. The issue is isolated to the combustion chamber and related components. A piston soak may help free the piston rings but there is no guarantee. Then carbon contamination of other components in the intake and exhaust system may cause worse issues like a burnt exhaust valve. I documented step by step my experience in the video below. It's an A7 but it's the exact same engine.
https://www.youtube.com/watch?v=apGCLNWxiuI
![](https://cimg2.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1504/20240314_090341_6993776edc5843009b81b7a2d8bd5833bee089ce.jpg)
My 2018 CREC Q7 has had on average 3k mile interval oil changes since it had 19k miles. Currently at 71k miles. All other maintenance items, including ZF trans fluid and differentials were done proactively. It even gets a new engine air filter every two oil change intervals.
The oil in those water jugs is new Valvoline 5w40 synthetic with 15 minutes of idle time to flush out the Liqui-Moly Proline motor flush solution. The oil looks as dark as the oil with the motor flush and 3k miles worth of driving.
#685
Questions on using an engine flush (e.g. Liqui Moly): how much do you add, one bottle of 500ml or two? Do you extract some oil so there is room for adding the flush, like expect the MM show half way between min/max before adding 500ml?
#686
@GlennR @keg97 @petery129@mhoran89 @TheBudgetBaller @silver_tt @kelisko
Updating the log again (new data in red). I'll be flying for the next month or so. Likely to not see much new data for awhile.
Oil details aside, I'm considering trading/selling the Q7. It needs a TON of deferred maintenance (tires, brakes, suspension bushings, S/C Clutch, PCV, fluid changes), to the tune of an easy $7k or so. I can either pot commit to the Q7 for another few years, or trade it away and get into something new. I'm less concerned about the consumption now that I'm logging and finding it to be faster than I like, but not absurdly bad. $7k is just a hard pill to swallow with my current situation of driving so much and having so little spare time. We'll see what shakes out. This is what I get for buying a German car during stupid COVID pricing back in early '21 then just driving it without staying current on maintenance.
- 97,118mi - Changed and full - 2023-09-25
- 99,616mi - added 1qt, light on - 2,498mi since last fill - 2023-10-17
- 102,594mi - added 1qt, light on - 2,978mi since last fill - 2023-11-18
- 103,604mi - added 1qt, light on - 1,010mi since last fill - 2023-12-07
- 104,454mi - added 1qt, light on - 850mi since last fill - 7,336 since last change - 2023-12-24
- 105,105mi - added 1qt, light on - 651mi since last fill - 7,987 since last change - 2024-01-03
- 8,022mi on change
- 105,140mi - Changed oil. 5W-40 Liqui-Moly, Fresh Filter - 2024-01-13
- 107,534mi - added 1qt, light on - 2,394mi since last fill - 2,394 since last change - 2024-02-04
- 108,928mi - Added 1qt, light on - 1,394mi since last fill - 3,788 since last change - 2024-02-25 (Castrol GTX "Euro" 5W-40 oil from AutoZone)
- 5,422mi on change
- 110,562mi - Changed oil, 5W-40 Castrol GTX "Euro" 5W-40, fresh filter - 1,634 since last fill - 5,422 since last change - 2024-03-09 (Light came on as I was pulling into the parts store)
- 112,461mi - Added 1qt, light on - 1,899mi since last fill - 1,899 since last change - 2024-03-18 (Castrol GTX "Euro" 5W-40 oil from AutoZone)
- 113,492mi - Added 1qt, light on - 1,031mi since last fill - 2,930 since last change - 2024-04-02 (Castrol GTX "Euro" 5W-40 oil from AutoZone)
Last edited by 2kwik4u; 04-03-2024 at 03:55 PM. Reason: Fixed date on latest entry
#687
I do love how you're sharing cold hard data with all of us. Thanks!
7K in maintenance, along with your decent oil burn, would likely push me to trading this in as well. Any idea how much you might get for it? What would you look at?
#688
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
Carvana offered me $11k over the weekend. CarMax said $13k. Average amongst KBB/Edmunds/NADA websites is $15.5k for a clean trade in. I owe just over $24k (that's what I get for buying in the middle of COVID crazy market).
$7k in maintenance is if I fix every single little thing that's wrong with it, put a tune on it, lower it, and flush every single fluid. Basically setting it up to run for another 3-4yrs without additional significant intervention. I drive a lot (~30k/yr average over 10yrs), so things like tires, fluids, and brakes are going to be somewhat constant with it. Just so happens they're all due at the same time on this cycle. I bought at 33k miles in March of '21. At 113k miles now, it's honestly been really good to me. Wheel bearing, water pump, brakes, tires, and a few interior bits are all I've really had to mess with. It still looks OK, drives decently, and does all of the "things" I ask of it, including towing a boat to FL once a year, and a myriad of other shenanigans one shouldn't subject a luxury SUV to.
I'm looking hard at a Titan. They are tough as nails and come with a 10yr/100k warranty. I like the look and performance, and they're an exceptional value in that segment. I've also considered a Durango R/T, GX550, and an Armada. I have a pre-order on a Silverado EV RST, but at $110k+ I'm not sure I can swing that budget. Wife is pushing me to trade the Q7 and her Rogue on a new Armada for her, then I take some cash and go find a B7 RS4, or B7 S4 Avant. I like the premise, but I'm growing tired of constant "car stuff", with 2 young kids, and a successful career, I don't want to spend what little free time I have swinging wrenches to keep something running.
We're in the middle of a move from Louisville to Buffalo, so I won't be changing the car until at least the middle of the summer. Just keep it running until then, and I can decide if I really want to fix EVERYTHING, or just get out of it and into something else.
keg97 (04-03-2024)
#689
If you are set on one, I highly recommend a PPI, leak down and compression test, scoping the cylinders to check for scoring and making sure the timing chains and components have been done already. There are unicorns out there for sure but the majority of them likely have issues.
dohturdima (05-17-2024)
