When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
No , AGM very likely good for 7+ years. Rather then pay double at dealer for batt and install, get one of those small lithium booster packs to carry with you it you are worried, will charge your phone too....
I have several in various cars, but like this one the best, about $100:
@billsfan I second what @Mesquite77 posted. I carry a small Li-Ion jump pack with me. Works for the car or the boat. Didn't cost much, and will usually get you home. For me, battery is one of those things I don't replace until the old one fails. It's not likely that it will hurt anything else when it does fail (unlike something like a timing belt, or suspension busing), and they are readily available for replacement locally within a few hours time if needed.
Run what you have until you start having issues, then replace.
AGM batteries in these cars if cared for (charged or driven regularly) can last 7 years easily. I would not sweat a 5 year old battery unless the car sees absolutely extreme climates. keep a jump pack with you (I do in the winter usually) as my ski trips have temps regularly below -20F.
My battery started to concern me last winter, when it was five and a half years old (was slow to start a couple of times). I purchased a battery tester and charger, which confirmed that it's nearing end-of-life (it's now over six years old). I'm proactively having it swapped at the dealer before this year's winter, but am kind of stunned at the price (>$700 parts + labor!). Dealer justified it as there's required seat disassembly due to the battery being under the seat.
I seriously need to open a shop. This kind of pricing is just nuts.
If you can get a battery tester/charger to the battery for, well, testing and charging, you should have been able to see how easy it is to remove.
The battery is in a small compartment under the passenger seat floor board. The compartment lid opens right up, and the batter lifts out of the top. You can do it with the seat in the full rearward position. I would be curious what part of the seat the took apart to get the battery in/out?!?!
With all that said, I've only looked at my battery for a date stamp, I haven't actually removed and replaced it.
Reason: clarity
Yeah, I'm used to dealer prices (owned a BMW for many years) but I'm particularly unhappy with this Audi dealership.
To charge and test I only have to connect to the jumping terminals in the engine compartment, so I had no need to access the actual battery.
I've read (in these forums) that the battery is surprisingly difficult to get out, so it wouldn't surprise me if the official Audi maintenance standard is to do something that requires a lot of labor like removing the passenger seat completely. But interesting that you say it's on the passenger side! They want to charge me to remove the passenger seat ANYWAY to change a seatbelt buckle, so it seems they are double-charging me for removing the passenger seat.
I just walked out in the parking lot at the office out of curiosity (and needing to take a break). It couldn't have taken me more than 12 seconds to get access to the battery once I opened the car door. I have ZERO clue why the seat needs to be removed to access it. Lift floormat and set aside, lift access panel and remove. There are two bolts that hold the battery to the floor, and the two battery terminals. I can't see any other fasteners to remove, or items to clear to get the battery out.
This is on a '17 Prestige. Maybe the '20+ models are more difficult?!?!
For whatever it is worth, I bought a '18 Q7 Prestige with 31k miles on it last year and it was 3.5 years old. It was based in CA and I think garaged based on its condition so it lived a cushy life.
I started having battery issues within the first 2-3 months of ownership and when the dealership went in to replace it under warranty they discovered the original owner had already replaced it with a Die Hard battery so they couldn't cover it under warranty. Luckily CarMax covered it so it all worked out but I'm surprised to hear many people last 7+ years with their battery given the one in my Q7 apparently only lasted probably 2-3 years at most given the Die Hard battery was dying in under 4 years since original delivery date.
I third the lithium ion jump pack. I have the same NOCO model as mentioned above and it saved my butt SO many times with my previous vehicle and a few times with the Q7 before I could get the battery replaced. Really is a huge added piece of mind and it only needs to be recharged 1-2 times per year if you keep it in your trunk for emergencies.
Wow, thank you for checking and providing the picture. I have a '17 as well.
Lead acid batteries need to stay fully charged at all times for maximum life. A car that is driven infrequently or for many short trips (where the alternator doesn't have a chance to fully recharge the battery) will have its battery degrade faster.
