When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
I also heard a loud pop back in July. Felt like a golf ball hit my side. Took the dealer recently for a check up and they found both rear springs broken. FFS!
i will report my issue. Is there a good DYI video/instructions for this. Dealer wanted $2600.
And alignment and another $800 to align the adaptive cruise control. What a bunch of crooks.
I have not found any DIY videos specific to the 4M but the B8.5 model uses the same set up and there are some videos on YouTube.
Absolutely no need for adaptive CC recalibrate.
this is a very easy DIY. Go to getaudiparts as they have the cheapest OEM springs and lower mount prices.
as I said previously just mark the eccentric bolt with something like a silver sharpie or nail polish and your alignment will be fine. Go to Harbor Freight and get some spring compressors.
@richsurf, do you need to drop the lower arm or can you get in and out with just the spring compressors alone?
I suppose you could just remove the outer bolt and press the arm out of the way
I took them out to treat the corrosion on the arm itself. It is a much easier job just to take them out. Just make sure to mark the eccentric bolt for alignment.
Can anyone tell what this part O1S is? It reminds me of the anti resonance weights on the LR3 and LR4. And more importantly, should there be two, one on each side? I only have one on the nearside.
Hmm, looked at a bunch of rear subframes on the ol' t'interwebs and most only have one or none so guessing I'm not missing one. Does anyone know the purpose? Is it to control the resonance?
2017 Q7 3.0 with 62K miles and just over 6 years old. Went in for the 70K service and was told that both rear coil springs were broken. I was told that this is a common failure/wear item from the service tech. I did not notice prior to the service appt. Over $2K for the repair. Should I expect the front coils to break soon and for this to happen again in another 6 years? I filed a report with the NHTSA, which I encourage others to do if you have springs failing. If this is as common as it appears, there should be a recall.
Forgive me novice here, trying to gain your knowlegde and help.
Hey there. I have an 18 Q7 prestige, 90k miles. Just put new vredestein tires 15 months ago. 12k miles ago. Rear driver side has been 2 inches lower for at least 2 years. Upon state inspection, mech says found a broken rear spring. He replaced both rear springs and shocks. Since then the ride is nowhere near the same. Dry road it feels loose on uneven road or potholes. Now it's winter and the truck feels super loose like its sliding on snowy or icy roads even at 30 mph. I took it back to mechanic and he says must be the tires... Should I take it for an alignment somewhere else? Not sure what to do. Should i be asking for them to look at something in this thread?
