Car turning off by itself when park?
#11
And that's one of the many reasons we are here, to help each other. If people have nothing helpful to add why bother, we all know we can find answers in the manual but sometimes while sitting at your office, or wherever, you may not have access to the manual and a question pops in your head, and you ask yourself " I wonder if other forum members have this issue / question". Nothing wrong with that in my opinion.
#13
You still need to press the button (with your foot off the brake) to tell the car you are leaving so it cuts off power to everything, like radio, A/C, lights etc.. Unless, pressing the lock on FOB does that for you, you can test it. I am comparing it to my X5, and it actually requires two pushes to completely turn everything off. One press to turn off the engine, 2nd press to turn off everything else, which you can also turn off by locking the car on FOB or touching the handle.
#14
According this this, if the engine is in a "stop" mode, and you press the button, the car will turn off. Just as I would expect it to. But the reason for this topic is that I think the car is sometimes starting when I press the button when in a stop mode-specifically when I put the car into park. Unless, as I first said, I am imagining it (or forgot that I had turned the car off). Just because I have my foot on the brake should not be a reason for the car to not power down and turn off as usual.
![](https://s1.postimg.org/803gdp0h8f/IMG_9990.jpg)
#15
No, that is not true because as you've likely observed, the car doesn't always shut down by itself when you are at a stop light or have put the car in park. There are many factors the auto start/stop folows. So if the engine is already off, all you have to do is exit the Q and hit the handle or fob to lock and shut down all power
#16
I was thinking the same thing the other day, "Why does the car keep turning back on when I press the ON/OFF button after I park?" I now have a better understanding of the "feature" and will have to test it out some more. It really doesn't sit well with my habit of pressing the ON/OFF button after I have put the car in park and I'm ready to get out. I don't know why the ON/OFF button needs to turn the engine on when it has been auto shut-off. The button is not necessarily an "engine" on/off button, it's an ignition on/off. If I put the car in park and it decides to shut the engine off 1/2 a second before I reach the ON/OFF button, that is completely unnecessary cycling of the engine components.
The internal combustion engine was not designed to consistently cycle on and off, in fact, this is one of the most stressful conditions for the engine to be in. read more here if interested: https://www.autocar.co.uk/car-news/n...r-car-s-engine
I'm getting used to the auto start-stop feature and trying to accept it, but the unnecessary restarting of the engine when I try to turn off the ignition needs to be re-programmed. I'm not going to change my habit to deliberately not pressing the on/off button as I exit the car, with the intention of the car's ignition automatically shutting off. Too many variables, maybe auto on/off isn't on, maybe it's not in Park, maybe I'm not in a car with this feature and I've developed a bad habit of not shutting the car off when exiting. Just doesn't make any practical sense.
#17
Too many times I'm listening to music loudly and park the car, unaware if the engine has shut-off and I press the IGNITION On/Off button, and the engine cycles. Completely stupid. No one is trying to manually turn on the engine when they press this button. It should just shut the ignition off, whether or not the engine is already off.
#18
Well ok, but are you also saying if you do want to turn it off with the button, as you normally do, it should not turn off but restart the engine?
#19
#20
