When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
CD/DVD player: Why did it take me so long to realize I had one?
OK... I just realized this past week (after over 5 months) that there IS a CD/DVD player in the glove compartment. For some reason, I thought that the only ways to play music & videos was via Phone or memory card.
hahahaha
Just started importing some of our favorite CDs into the Jukebox.
Did you code your Q7, how are you able to import your CDs?
No, i did not code the Q7... just put the CD in, and chose the menu option to RIP them into the car.. now they are there without the physical CD in the player.
I have over 80 CD's on a SD Card. You can place your music into folders ( i.e. Bruce, Allman bros , U2 etc) leveraging a PC. However the ability to end an album and start with the nx consecutive one does not exist. The program brings you back to the beginning of the alphabet .. Not very intuitive
i believe the juke box only holds up to 10g Obviously a SD card is much larger
I have yet to place CD's on the juke box and curious if you have better selections / options
You can create playlists for this. I've just done it with windows media player, but I think you can just make a simple text file with relative paths to each file on a line. (the other alternative would be just do folders as playlists, you can prepend the file with a number just use leading zeros to be safe or likely it will alpha sort rather than numeric. (ie 1 - < name>, 10 - <name>, 11 - <name>, 2 - <name> ) instead of ( 01, 02, 10, 11)
I'll mention the following caveats with playlists because whoever wrote this software clearly never used it:
1. when you start the car you will see the 'loading' screen about 98% of the time until the track changes.
2. it seems like if you have a playlist named "myfavs" (or w/e) and you update it, the car must read the original one into cache and will not process the updated playlist, if anyone knows how to reset this I'd appreciate it, otherwise renaming to "myfavs1" fixes the problem
2 more issues not playlist specific:
3. the cd sounds better to my ears (its subtle and I don't think I could identify in a vacuum but switching back and forth between the same song I can hear a difference)
4. there's a 1 second or so pause between tracks, only noticeable if you're listening to a cd where the tracks segue together. (eg: Dark side of the moon)
Did you check the link above? It says you cannot do it. I actually tried it myself against below notice, and there is no option to import CDs when you put a store-bought CD into the CD drive. Could be different if they were created/burned at Home, though.
