Clunking Sound on right side of vehicle
Has anyone noticed this? if you jerk the wheel slightly right and left there is a clunk clunk that sounds like something is loose on the right under side of the car.
I went to look underneath and its completely sealed so i cant even see if there is a loose catalytic converter.
BTW, the creaking on the steering column is out of control even when barely turning the wheel 5 degrees to the left of right.
"Time for a checkup, time for a checkup"
I have a clunking noise that happens if I pull up to back into a parking spot. So pull up with the wheels one direction, stop, turn the wheels the other direction to back up and that is when the clunk happens.
Sounds like it is coming from the driver side from wheel. Something loose possibly with steering control arm. Need to find time to get to the dealer.
im about thiiiiiiiiiiiiiiiis close *holds fingers 1mm apart* to dumping this POS and buying a honda.
A6turbo530
39
12-09-2008 09:10 AM
A3 4 Me
07-05-2003 04:48 AM
shaker
04-08-2002 02:45 PM
1996_a4_2.8Q
09-11-2001 05:13 PM
