Front Parking Sensors
#21
So the big question is: Is there a setting within the MMI that causes this to work (even if it's an indirect change of a related setting), or did the ones reporting that it does work all have a software update at the dealer (possibly unrelated) that could have invisibly applied this feature? Hmmm. Logic would say it must be one of the two. Would be a nice feature to have.
#22
Enable Automatic PDC Front
[09 – Central Elect.] [Coding - 07]
Select Long Coding Helper
Select Bye 37
Check Bit 1
Exit Long Coding Helper
Click Do It
https://www.audiworld.com/forums/a4-...weaks-2898879/
#23
someone with VCDS (or a dealer with some skills) can enable this even on older cars
Select Bye 37
Check Bit 1
Click Do It
Select Bye 37
Check Bit 1
Click Do It
#24
No, I don't think my dealer did any programming for me.
I actually asked them to program the delayed lift door and default ACC range for me when took delivery and they said they are not capable to do it. Since I took the delivery in mid-July, I haven't go back to the dealer yet. I think the main difference might be the firmware version. You should check if yours is on the same 0692 version.
#25
Thank you. Okay we are a step closer. My software is 0443. Perhaps others with and without the feature working could chime in and report their firmware version. This could very likely be the answer to the mystery. Thanks everyone!
#26
#29
One of the first differences I noticed between my 2013 Q7 & this new one was that the front parking sensors didn't come on unless you pushed the button (a feature I really want).
I've been beating up on my dealer to get them to activate the ACC default distance menu, so now this gives me something else to fight with them over.
BTW, Meycul, your navigation database is out of date. Latest is NAR 2016/2017.
#30
Also, can someone tell me if the sticker with the model and month and year of manufacturing is this one:
![Front Parking Sensors-photo224.jpg](https://www.audiworld.com/forums/attachments/q7-mkii-discussion-211/58671d1480539664t-front-parking-sensors-photo224.jpg)
