Goodyear run-flat and puncture repair
So yesterday, one of the Goodyear run-flats got punctured by a screw. Several minutes after TPM alarmed, I pulled over and checked the tire pressure using a gauge - it was about ~17 psi. Soon after, I got the screw removed and the puncture plugged using one of those plug repair kits. So far, there has been no air leak fortunately.
However, knowing that a more proper repair involves patching the inner tube, I called two tire shops to see whether they can still do the patch after the plug. To my surprise, both shops said no due to the tire being run-flat. However, an assistant manager at a nearby Goodyear told me that even though they cannot do the patch, local mom-and-pop shops may be willing to do that.
Here are my questions:
1. Is it feasible and beneficial to patch a run-flat that has already being plugged?
2. When you get a screw in tire, air leaking fast, and you don't want to be late for too long. With run-flats, you basically have two options:
a). Continue to drive X<50 miles at a speed of 50mph or less, and then bring it to a tire shop for proper repair;
b). Use a plug repair kit and be back on the way in <20 mins.
When would you prefer option a) to b)? It appears that the more you drive a run-flat without air, the more damage is made to the sidewall, and less likely the run-flat can be repaired. So it appears that option a) is better if and only if X is small, say less than 20 miles?
If the puncture is in the center of the tire tread, away from the sidewall, I'd say plug it. Many will plug it for you. But you are correct, get it plugged asap like take it straight to a repair shop and minimize driving on the sidewall.
I had a nail in a tire and called around. I finally found that a Goodyear dealer would do it. I later noticed they scuffed up the rim in the procedure.
Ultimate Keyboard Warrior
Tire Repair
Like any other Goodyear or Dunlop speed-rated, high-performance tire, the Goodyear Run-Flat tire may be repaired to correct a puncture in the tread, but PROPER MATERIALS AND PROCEDURES MUST BE USED. Contact a Goodyear or Dunlop Run-Flat service facility for information on proper repairs. For the location of the nearest facility, call 1-800-GOODYEAR (1-800-466-3932).
https://www.goodyear.com/en-US/tire-...eplacementLink
Tire Repair
Some holes will require a proper patch, though. I would go with a plug whenever you can, it will either fix or not, and if you get a leak, go back and get a patch.
Secondly, you don't patch a tire after plugging it. The plug is cut flush with the exterior of the tire but has a tail inside the tire. You can drive on plugged tires for a long time. "a driver can get a quick tire plug and drive another 20k miles on the tire with no problems." Read here: https://www.carsdirect.com/car-repai...-patch-vs-plug
I would prefer option a to b if I needed four new tires soon anyway. Just get them all replaced. If you pick option B, worse comes to worst, the air leaks out very slowly, you still have run-flat tires, and you get it truly fixed/replaced later.
perlvater
05-22-2007 09:13 AM
watty
04-27-2004 04:33 AM
