How do I install the map update via the SD card?
Old 07-22-2017, 09:44 AM
Brimstone's Avatar
Default How do I install the map update via the SD card?
For starters where do I even get the map update? Its not at myaudi.com as described in the manual. I found something on another computer (installed the Java) and downloaded it, but alas after copying it to SD card, when I got to install from SD card in the MMI its greyed out, which suggests to me, I either missed a file or put it in a directory structure it doesn't like.
Any clues would be appreciated.
Old 07-22-2017, 10:08 AM
Brimstone's Avatar
Ah in the myaudi.com site you can go to "audi connect services" and I was able to find the map update.
Old 07-25-2017, 09:40 AM
Brimstone's Avatar
Update, I got it to work, after I redownloaded (may or may not have had a corrupt file originally, looks like there are 2 files and 2 directories)
They just need to be in the root directory of the SD card, I had them in a subdirectory originally, oddly once I did this it was unable to recognize my music. After the install I deleted the files and the music was recognized again.
Old 07-26-2017, 11:31 PM
Atvars's Avatar
Very straight forward and simple process. As first 5 map updates are for free, don't miss this.
1. Register to myAudi.com, add your car there by entering VIN.
2. Download map updates to SD card (for whole Europe, 32gb SD card is needed).
3. Install it to your car. Installation is performed in the background, even when car is switched off.
Attached Thumbnails How do I install the map update via the SD card?-downloadmaps.jpg   How do I install the map update via the SD card?-wp_20170727_09_33_49.jpg
Old 07-27-2017, 08:28 AM
Atvars's Avatar
16.2 Gb of full EU maps version 2017/2018 installed.
In fact, map was not fully installed when I started the car in the evening. It seems, that it stopped installing after 10-15min I left the car. When I started to drive home, it resumed installation and finished in 10 min.
So it is not Tesla with big battery, that install updates during the night. Audi shuts down all the systems after you leave the car.
Attached Thumbnails How do I install the map update via the SD card?-wp_20170727_18_10_29.jpg
Old 07-28-2017, 06:41 PM
Dasaint's Avatar
The 2017/2018 us maps are availble too
Old 07-29-2017, 04:21 AM
gsobol's Avatar
Wow, nice house :-)
calculi (04-01-2020)
Old 07-29-2017, 12:26 PM
kdkrone's Avatar
My map began updating within two days of purchasing the car and registering for Audi connect
Old 08-17-2017, 04:45 PM
OneOfOne's Avatar
I thought that these maps are supposed to update OTA instead of needing an sd card
Old 08-17-2017, 05:09 PM
OneOfOne's Avatar
https://www.audiworld.com/forums/q7-...dates-2923986/
Quick Reply: How do I install the map update via the SD card?
