OBDEleven
Old 12-29-2017, 05:08 AM
  #581
bhatiaax's Avatar
Originally Posted by RickObe
(Also for bhatiaax)
Here are my most up to date notes for other stuff I've done or rejected:
Rick - you are the man. I saw in a post that you said you don't want or like VIM. But do you have coding for it? Thanks!
Old 12-29-2017, 05:09 AM
  #582
RickObe's Avatar
As far as I remember seeing, VIM can only be done with an OBD11 app and that app is not updated for more recent (2018) builds. Sorry, I don't have any more info.
Old 12-29-2017, 05:12 AM
  #583
RickObe's Avatar
Originally Posted by Lectoid
I do for several months in the spring and fall in North Carolina. I don't even use the A/C until it's really hot out.
You can turn the A/C off without turning the whole system off (green arrow vs red arrow in picture below). I think the coding will work with just A/C off but not whole system. However, I have not actually tested that. If you need to turn the whole system off (or if the coding doesn't work with just A/C off), then you are probably going to be annoyed by the start/stop cycling even with the coding in place. Unfortunately, I don't know of any other or better options.
Old 12-29-2017, 05:18 AM
  #584
anemeth's Avatar
Re: Mirrorlink, see link below:
https://mirrorlink.com/
Old 12-29-2017, 05:22 AM
  #585
bhatiaax's Avatar
Thanks Rick, not a problem. I am waiting on the product to arrive and will bother you again with more questions
Old 12-29-2017, 06:25 AM
  #586
Shredderman 3.5's Avatar
My loaner SQ5 had static cornering lights. Turn the wheel and the corresponding all weather light would illuminate. Anyone know how to code this feature into a Q5 with an OBDEleven? Couldn't find it by search.
Old 12-29-2017, 06:36 AM
  #587
Lectoid's Avatar
Yea I'm aware. My previous BMW was the same way. I rarely use the A/C so I had gotten used to turning it off almost every time I hit the auto button. I'm one of the few that, so far, doesn't mind the auto off. There are a few lights that take a long time so it's not bad. And I've figured out that feathering the break will keep the engine running and a hard press will usually turn the engine off. Also shifting to S will disable auto stop/start as well.
Old 12-29-2017, 08:18 AM
  #588
Paul Collurafici's Avatar
Default MirrorLink
Thanks Rick. So for IPhone users this is not needed, just use AppleCarPlay.
Old 12-29-2017, 09:19 AM
  #589
mctt197's Avatar
I have a 2017 Q7. If I put the headlights in the "Auto" position, the 'cornering' lights work.
Old 12-29-2017, 07:30 PM
  #590
Mine are in auto also, but no cornering lights.
Quick Reply: OBDEleven
