When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Hey guys I have a 2018 audi q7 prestige with 20" wheels
I was looking on getting aftermarket wheels and need help with fitment. I was looking at this set up
21X10.50 + 45 off set
Tires would be 295/40/21
Would this cause issues or any rubbing? Also will the wheels be flush with this off set and size.
Does anyone have aftermarket 21 or 22s with similar widths?
I run aftermarket 22's 22x10.5 et15 and et20. I think you would need spacers to push those wheels out. The stock wheels from what i remember are 9.5 with high 20's offset.
stock wheels are already somewhat flush. Wouldnt a 10.5 with a 45 offset be flush similiar to a 9.5 with a 31 offset
depends on your definition of flush. but the concern would be inner clearance and rubbing on the strut. a wider wheel with less offset might cause fitment issues.
Getting mine installed tomorrow which are the Vossen HF1s in 21 x 10.5 offset is 30, and I am running 295/40/21. Will let you know how it turns out!
Was actually looking at that specific rim as well! Please post photos.
Here you go... just got installed and they came out great. I did not lower the car or adjust the high at all using the normal setup (no air suspension)
Vossen 21 x 10.5 HF1s in Tinted Graphite.
Just need to matte grey the window trim and roof rack and I'm done.
