Rear License Plate Mounting (USA)
Old 04-07-2017, 11:44 AM
Cadx6's Avatar
Default Rear License Plate Mounting (USA)
Anyone have any reasonable solution to the dreaded "spinning captive nut" problem on the rear of the 4M Q7?
I went to install my "summer" license plate frame (long story involving bunches of salt on our roads) & when I tried to remove the plate with the dealer's frame the top captive nuts just spun along with the screws. I finally got them off & found that the snap in captive nuts had elongated their holes allowing the captive nuts to spin. I removed the two torx screws in the plastic mounting base but something else is holding it on, otherwise I could get to the backside & devise some type of solution.
Anyone have a fix or know how that plastic mounting base is attached other than the two screws (I'm leery of excessive force when I don't know what I'm doing).
Old 04-07-2017, 12:13 PM
SYMAWD's Avatar
Just double sided tape. Heat helps, but you can just pull it off.
Old 04-07-2017, 12:40 PM
Cadx6's Avatar
Thanks - would have never guessed such a high tech attachment method . I seem to remember this "spinning captive nut" was a known problem. Has your dealership had any?
Old 04-07-2017, 12:56 PM
Keyser Wi's Avatar
@Cadx6
Somewhat off-topic but this will protect your plate from salt (or dirt, etc.):
License Plate Covers - Clear Cover Waterproof License Plate Protector | WeatherTech.com
I'm using them and have no complaint.
Old 04-07-2017, 01:01 PM
Bozman5000's Avatar
I have a cover like that I've had for 15-20 years now, works like a champ. Not weather tech.
I just had to replace the tab on my plate and had the problem of one hold being stripped. I don't think it's going anywhere but will try the tape idea.
Old 04-07-2017, 01:09 PM
Keyser Wi's Avatar
Weathertech cover is very well made, but fits quite tightly at the rear due to the rear view cam. The small inconvenience is I have to remount it every year for the new tab.
Old 04-07-2017, 02:01 PM
Cadx6's Avatar
Originally Posted by Keyser Wi
@Cadx6
Thanks- I've seen those at Weathertech when I've picked up mat sets for our cars (they're only a few miles from my house). I occasionally wander into their retail store just to check out the "in store" sales they have on discontinued / overstocked stuff. They do make quality stuff.
Technically they're illegal here in IL, but that wouldn't really deter me. I have a slightly smoked one on the front of both my A4 & Q7 that protects the front plate from debris, salt, etc. Plus it looks good on the Glacier White cars.
Old 04-07-2017, 02:30 PM
PROEDGEBIKER.COM's Avatar
Although not enforced by many officers, in FL is illegal to have any, and i mean any type of covering on a license plate. They will get you under this law: Statutes & Constitution :View Statutes : Online Sunshine
It was just recently brought to light in a case that i saw in the news a few months back:
Your license plate may be illegal under new law - NBC-2.com WBBH News for Fort Myers, Cape Coral & Naples, Florida
Old 04-07-2017, 03:31 PM
acura_audi's Avatar
I went to the local dealer and they replaced with front mounted plastic inserts no/charge.
There is sticky tape behind the plastic holder - the service dept. knows how hard to pull.
Old 04-07-2017, 09:07 PM
diffuser's Avatar
I went to the dealer and got the entire bracket replaced.
Twit
05-18-2019 06:16 PM
ejudgie
S4 (B8 Platform) Discussion
05-09-2017 06:20 AM
m3brad
Audi A3 / S3 / RS 3 MKII
06-02-2015 09:18 AM
Pinball81
10
03-10-2004 12:19 PM
airbil
02-17-2003 07:54 AM
Quick Reply: Rear License Plate Mounting (USA)
