Speaker Rattle
Speaker Rattle
Does any one else have an issue with their speakers rattling during a bluetooth phone calls? I only notice it on phone calls. I have the bluetooth volume all the way up on my phone. I find the volume on calls to be low and have to have the system volume at 80%+.
Do you have base Audi, Bose, or B&O? What are all your sound settings on the phone and MMI? What phone?
Did you guys solve this issue? I picked up two days ago my SQ7 and Iphone SE over BT is crap. I also have BOSE. Volume all the way up and it quite and rattling. When I needed to charge I connected lightning cable to USB. Phone switched voice over the cable and it was perfect. Nevertheless I want BT working same way. Maybe you have solved that
Audi Q7 Speaker Rattle issue
I have the same speaker rattle issue when i connect my phone thru BT and make calls. This happens when input the volume to max. I took my car to the dealer and first they thought it is a speaker issue and changed my BOSE speaker on the dash. But that didn’t resolve the issue. Then they put some kind of material that audi provide to help with the rattle. That did help but it didn’t solve the issue fully (it solve around 80-90%). Then they demonstrated on other Q7 and showed my that it is an issue with most Q7s. I have a written statement from the dealer on that. I am really disappointed that the 2017 Q7 were put into the market this the issue. I expect better quality from Audi!!
I have the same noise / rattle when I use the phone and some types of music, I first thought it was a blown speaker but a friend has a 17 Q7 as well and I heard his make the same noise. My A4 got a recall for a rattling speaker grill, I wonder if we will get a recall on the Q7 soon?
Audi Q7 Prestige'18 Owner
OK.. getting technical here... I do a lot of work in the Audio recording, as well as in live audio mixing.. the sound and symptoms you describe may not be the speaker at all. What I see being described is what i would call "Over Driving" the inputs.. in other words, the output of the iphone is "too loud" or to high for the input to accept. When this happens, it makes a raspy sound. I have experienced this with devices in audio mixing. Someone has their guitar amp output turned up too much, and it doesn't matter how much i turn down in the speakers, it sounds bad.
The "Fix" in the Audio Mixing world is one of two answers:
1. change the "Pad" on the mixer to allow for higher input
2. lower the output on the guitar.
All that said... in theory, it could be a problem with how the interface is between the iphone output and the input into the audio system. Perfect speakers can still perfectly play a rattle sound.
