Tire Pressure Reading in MMI?
I purchased a new 2019 Q7 early this year and am new to Audi, so when I received a low pressure warning this weekend I immediately when into MMI to see which tire was low...only to be confounded by the fact that it appears Audi does not provide individual pressure readings by tire through MMI. Is this correct or am I missing something? I have owned BMW , Lexus and Mercedes for years, all of which provide individual tire pressure readings through the onboard computer. Will be amazed if it turn out that Audi does not. Thank you in advance!
Jailor (09-14-2020)
I don't like that Audi doesn't have the handy feature my half-the-price-of-an-Audi Camry has--individual tire pressure readout on the infotainment screen.
Jailor (09-14-2020)
This feature is not brand specific but rather model specific. On the Q7, Audi has elected to use a passive TPMS system that uses each specific wheels ABS sensors to measure relative rotational speed to detect a loss of pressure. This system is sensitive enough that it will be able to detect a small loss of pressure via a change in rotational speed even when run-flat tires are used. BMW, Mercedes, and others use this passive system as well on various models and some seesaw back and forth between active and passive systems based on model year even. The benefits is that passive TPMS basically serves the same purpose as active TPMS but at a lower cost because it uses sensors that are already used by other systems in the car, and that regardless of what set of wheels you use on it, it will still be active without having to purchase and install a second set of valve stem sensors for each wheel. The downside is not having the cool factor of actually viewing live individual tire pressure and in come cases tire temperatures on the instrument panel or infotainment display. On other models, Audi does use active TPMS, and in some cases it can vary by market/region. In my former RS7, each wheel had valve-stem sensor that relayed pressure and temperature data to the display for each corner. While I really like active TPMS systems like this, I don't like how I have to buy a separate set of sensors for an extra set of winter wheels, etc. Since I use a second set of winter wheels on our Q7 and now SQ7, I actually like the fact that it has the passive TPMS system. My BMW M5c has an active system and when I purchased a second set of winter wheels, I did not enjoy having to pay an extra $600 for a set of sensors due to its active TPMS system.
Dave_ (09-14-2020)
But it benefits everyone who runs a second set of wheels/tires during other seasons because you do not need to purchase direct TPMS. I really appreciate this...
mbs (09-14-2020)
Cost savings, eh? Like the lack of an under-the-hood light. For the price of an Audi I'd think they could manage to put in some common features. When they do include an expensive item, it is an extra cost item, such as the Laser lights for $1600 in the US, despite them not being functional as they are in Europe.
I, for one, would like to see the actual readings even at a cost. For Audi, they can make a system that's compatible with both - if active TPS sensors are present, rely on that system; otherwise, the inactive kicks in by default. Or better, when both are present, cross check - if either reports a low pressure, trigger a warning.
