VCDS mods on 2017 Q7
#101
You sure you cant do this already? Can you store radio stations already?
If so, go to your Nav screen and scroll down to a recent destination you had in your Sat Nav. The buttons will store from the recent destinations. Find one, scroll to it, then hold the button down on the touchpad. It should then store it.
Same goes for telephone. Scroll down through last call list and find the number you want to store. Hold relevant button on touchpad down to store it.
Let me know if that works or not.
You can't store MMI Setting "screens" on the touchpad buttons sadly. I'm in the UK and its not possible, we spent ages trying...
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Good luck
Andy
#102
RickObe
You can't store MMI Setting "screens" on the touchpad buttons sadly. I'm in the UK and its not possible, we spent ages trying...![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Good luck
Andy
Good luck
Andy
#106
Thanks! I just ordered an OBDeleven, so hopefully I'll be able to fix it one day. Also, I've got mine going in tomorrow for the airbag recall. They said they'd "try" to update the software. We'll see. But if they do, maybe it will fix that plus enable automatic activation of the front prox sensors.
#107
Yeah, let us know how it goes RickObe at the dealers
Regarding the other thread and the front Prox sensors, I dont believe "I am wrong" as its enabled on my car and mine was built in Oct 2015. But hey, each to their own with their opinions.
Good luck
Andy
Good luck
Andy
#108
@andyhud If someone said you were wrong, I don't think it was me. From what I can glean from that thread, it seems the automatic front prox sensors may depend on country and, for the US, the date of production.
#109
yes but usually most people only want one or two tweaks and once you do it once its easy to repeat .plus the car only goes in every 10k miles now so basically once every 8 mos you may need to tweak the software..secondly I have taken it in a bunch on other audis where some tweaks get wiped and others like needle sweep end up staying..so not everything gets wiped out ..depends what they do .
#110
Speaking of VCDS, just traded in my old HEX-CAN for a HEX-NET and I'm amazed at how much quicker and more responsive the new interface is. I don't know if it's the HEX-NET or just the Q7's system being quicker, because the last time I used the HEX-CAN on the RS7, it would pause or hang quite often when trying to communicate with the car. Communication between Q7 and HEX-NET seems instantaneous by comparison.
