034 EFI BTDT?
034 EFI BTDT?
<center><img src="http://pictureposter.audiworld.com/45998/intaketotb1.jpg"></center><p>Thought I'd share a peak at the 83... Lots of 034 parts and some homemade stuff too.
Anyone recently wired a 034 IIC for a 10V and have pointers? I'll probably start the wiring this weekend.
Mike Bond
Mike Bond
have you seen the threads on Motorgeek about material and connectors?
CPC connectors are ideal for the main disconnect between the ECU and the wiring harness.
I used a factory audi rubber wiring harness boot at the firewall and set the 16 pin CPC connector close to the ECU.
From there I mimiced a factory Harness with Bosch junior connectors. REcommend Heat shrink tubing and Raychem tubing and labels. You can make the harness modular by using more quick disconnects like 8 pin CRCs etc. That makes it easier to modify in the future if you are so inclined.
audiwerld
Audi Original "S" Cars
10-27-2017 02:44 AM
dtompsett
05-01-2007 05:40 AM
Sloooo4esT
07-23-2006 09:54 AM
