Blinkers?
I got my blinkers to work...finally. Found the switch buried behind the gauge cluster. The hazards work on both sides, but if the switch is off I get blinking from the ride side regardless of stalk position...i've tried replacing the relay and that didn't do anything...but it did turn off when I removed it. Any suggestions?
Assuming no really messed up wiring, the only place left and right signals meet are at the 4 way blinker switch, and the turn signal switch.
It almost sounds like the 4 way blinker switch has not completely returned to 'normal turn signal' mode, yet isn't comepletly in 4 way blinker mode either...
Try turning on and off the 4 way blinker switch a few times, and see if the situation imporves.
In my case, the 4 way blinker switch doesn't always let my turn signals work, without turning it on and off a few times...
StevenH
08-05-2022 10:36 AM
chapman62083
01-25-2012 10:51 AM
A4wheelin
01-23-2008 04:33 PM
