Relay socket jumper wire
On a early style (underdash) fusebox, there is a relay socket that uses a jumper wire, no relay, from the factory. My jumper wire came out. I need to determine which two terminals that the jumper bridges. The relay socket terminal are numbered, anyone know the correct jumper wire position?
Thanks
Thanks
Hey Thanks.. looks like it jumps terminal 10 to 13. Yours must be a later edition than mine, the fancy bent metal jumper and all. My jumper is just a piece of wire with two male terminals on each end.
Actually I think mine are numbered 13 & 14. You can just about see the #'s in the pic. The right side spade is just my trigger for some accessories that I have tied to ignition ON. Pretty sure mine is not newer than yours.
JacobB
06-29-2004 06:54 PM
JustJeff
05-04-2004 06:09 AM
imaudi5
10-20-2000 08:14 AM
