what are the solutions for the oil cooler on a 3b swap
For all who have a 3b swapped into their urq- what different solutions are there? I would like to use the urq oil cooler since it fits in the car better.
Thanks,
rick
Thanks,
rick
..with AN fittings and metric -> AN adapters at the oil filter housing. Should be doable for around $200-$250 in parts.
You could also buy Metric -> AN adapters for both the oil filter housing and the Stock cooler (or a 200q cooler) and then connect the two with AN hoses.
YOU CAN USE THE 3B COOLER AND LINES,REVERSE ONE LINE AND MOUNT COOLER AND USE 200 AIR DUCT TO COOLER, MAYBE BRANDON CAN POST PIC OF HOW I DID HIS
<center><img src="http://pictureposter.audiworld.com/56762/oilcooler.jpg"></center><p>.....if you bought a cooler that was just a little bit shorter (1, maybe 2 rows shorter), you wouldn't have to cut the core support at all.
<img src="http://pictureposter.audiworld.com/54627/urqoil1.jpg">
<img src="http://pictureposter.audiworld.com/54627/oil_cooler.jpg">
<img src="http://pictureposter.audiworld.com/54627/dscf0012.jpg">
Excuse the mess etc. that was a long time ago, before my Concourse De'Elegance phase..
RussB
03-12-2003 03:56 PM
