BAD GAS??
Has anyone else ran into the problem of pumping irregular gas into their cars?? I filled up on Friday @ a Conoco in Parker off the I-25 & Lincoln...and my car stalled within 5 miles of the station, and wont start at all.
Am I the only one??
Am I the only one??
Was your car totally out of gas when you filled up? Because unless it was I doubt bad gas would have impacted you so quickly. If they truly have bad gas others will be impacted. It would have to be REALLY bad for it not to burn at all.
Is your fuel pump okay? What are the symptoms? Is it getting fuel? Maybe the fuel filter is clogged?
Could be any number of things that are keeping your car from starting again.
AudiWorld Expert
It's rare for a major brand like that to have issues. But Shell had some issue in the SE US a couple of years ago but others would have the same problem - not just you.<ul><li><a href="http://www.gcmonitor.org/article.php?id=257">Links</a></li></ul>
AudiWorld Expert
and yes a slug of water can stop a car.
He can put in a can of treatment for water in his tank but I agree he needs to diagnosis the real root cause of his problems first
So I had an unfortunate mishap over this labor day weekend, and hope someone can give me some pointers before I have to resort to the "stealership".
Last Friday I had taken my A4 1.8TQ to the gas station, filled the gas tank and got a car wash. The car sat in my garage all saturday and sunday. Monday morning I woke up early to hit the golf course with a friend. Within 5 minutes into the drive the car started to "buck". Nothing like the hesitation you get or the misfire symptoms of a failed coilpack. Eventually the car stalled at a stoplight. I attempted to start it again, and it will idle for about 3 seconds @ about 300rmp before it stalls again. I disconnected and reconnected the MAF--no change. The car doesnt give me a CEL either, which I find kinda strange. When I attempt to start the engine, as soon as I push on the accelerator to give it gas, it stalls. I have no indications of leaks of any kind.
No changes made under the hood....just a full tank of gas. Thought I could have gotten some bad gas??
My truck barely ran and I had to keep it in first second to keep from stalling. I drove about 50 miles, then four bottles of fuel system cleaner and several gallons of fresh gas got me back to normal. A week or so later I dropped the tank to check the sock filter and replace the fuel pump, nothing to be found in there. I think some crud was in the fuel but I dissolved it with fresh gas and fuel system cleaner.
It sucked.
-Joel.
It sucked.
-Joel.
09-25-2015 05:24 AM
