K04's with APR Stage 1 KO3 software - why does my boost spike to 20psi and then cut?
So I just finished my center vent boost gauge, which I'm somewhat satisfied with. Once I finished with it, I went and made a quick highway run, where I confirmed that, at nearly WOT (or pedal floored, translated whatever the pedal is telling the motor), I am getting 20psi until my boost cuts to almost zero.
Is this the symptom that an MBC helps, or is there something else going on here?
Is this the fun of tuning a 2.7?
Thanks
Bob
Thanks
Bob
You hit throttle cut because of a deviation between requested and actual boost
4psi will trigger it on most software. Like I've said previously though, APR K03 software does not like being tweaked for K04's.
An MBC won't stop throttle cut, it'll just limit the spike to whatever you settle on (<20psi). If you want to run 20psi on K03 software, you need an MBC (standalone) and a TCD, and a custom 1600mbar one at that. An MBC in parallel on APR K03 code won't allow you to run that much boost, because the N75 is still controlling it.
An MBC install can be done by a monkey on acid, and as you did you're own turbo swap, you'll have no issue. Literally take the wastegate hoses from the N75 (bottom and left side) and plug them into the MBC. Leave the N75 connected eletronically so as to not trigger a CEL, and with the 2 remaining connections (that you just took the wastegate hoses off), loop them back to each other with another hose. TCD install is a little more complex because you have to solder, but I have install instructions for that if you decide to go that route.
And BTW, I picked up a hoist, so I'm good.
Good to hear on the hoist, and thanks for confirming intuition
Seriously Nigel, I have read so much about MBC in conjuction with N75, that it's somewhat confused *this* monkey on acid.
This is what I was thinking.... the ECU sees too much boost, and then shuts her down. So, on WOT, my power curve looks like a playground slide - sharp uptick (stairs) when the turbo finally spools, and then gradual let down as I start building "normally aspirated" power but lose turbo charge.
I think, as you've suggested, I will just go standalone MBC, and try it with the APR. I mean, I'd rather my tax return go to something else than another part for this vehicle. And soldering is no worry if I need the TCD.
Thanks again, and let me know if you need a night or so of help as you yank or reinstall your engine.
Best
Bob
Best
Bob
17psi is not an option, and yes, I know, proper software would be great....
...but I have the APR chip already in my junk, and allroad ECU's aren't swappable because of an immobilizer issue, so I'm just going to give it a whirl (free, after all) and see what happens.
iestatic
S4 (B8 Platform) Discussion
20
07-15-2022 09:43 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
Fixeroh
Audi A3 / S3 / RS 3 MKII
09-09-2015 02:37 PM
