Need 3 Audi tools for my timing belt job. Does anyone in Denver metro have these that I can rent?
- cam lock bar
- crankshaft lock pin
- chain tensioner tool
If there was one other tool I would have wanted it would be a cam gear puller.
lock pin and tensioner tool. Can't you just use a 2 jaw gear puller for the camshafts?
the crank doesn't move once at TDC. You will need it for crank seals though. The cam is the one to worry about.
But, you can use a 2 arm gear puller for the cams. Don't use a 3 arm, I've seen cases where people have scored cam gears using a 3 arm.
