So I spoke with a state rep. from the Colorado emissions department...
#21
manager. I just called a indipendent emissions station in Lakewood (Jerry Emissions) they said that Colorado Air Care has the monopoly on all non disel autos newer than 1984.
Damn!! Thanks for the sugestion though it was worth the try.
#22
the surrounding counties in order for the emissions test to be valid. Also the guy I spoke with at the DMV will not register a car that was tested outside the county it is being registered in.
#23
and it says exempt from 2WD dyno testing, not all dyno testing like I thought.
Regardless, here we don't have to get anything <5yrs old tested, and when it is tested, it's the tailpipe sniffer only. Freaking Jiffy Lube did my old car....
#25
They seem to have what looks to be a very safe AWD sniffer. It looks like an AWD Dyno with the rollers it has. They've never givin me trouble, but I only have 17"s.
Sorry if this is something you already know or have tried.
#27
There ARE independent shops I believe who ARE state licenced to perform this work...... and I mean like the corner gas station!
this COULD be a boulder/weld county issue though.
even if not, I'd try EVERY "colorado air care" facility (and obviously don't SAY anything when you go in) before I started replacing brakes to make it work!
R
R
#29
All late-model vehicles registered in the targeted front range counties (Denver, Jefferson, Adams, Boulder, Douglas, don't know which others) can only get emissions-tested at the CAC load simulating wheel-dyno centers. If you're lucky enough to reside in Weld or other "rural" counties then you can go to the corner shop for an old-fashioned tailpipe check.
It's a scam, scam, scam, and I think it will take legislative action to change it.
