Sway bar question
Is there any reason, when adjusting an anti-roll (sway) bar, to adjust them evenly on each side? In other words: if you have multiple holes is it necessary to have the drop link be in the same hole on each side?
I think not, because the load is spread out from side to side. Being able to only move one hole on one side would double the fine tuning that I could do on the bars' settings.
The other side of the argument is that moving one side unevenly will pre-load the suspension and make the car turn differently.
Thoughts??
Thoughts??
This is from one of the better tech's on Rennlist, I think it makes sense:
"Mark a few things.
From a Physics perspecitve, you are correct that using different holes in the same bar will give you a different stiffness. Now from a Geometry perspective, without adjustable drop links you WILL put some preload into the sway bar."
"Mark a few things.
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
Nish
S6 (C7 Platform) Discussion
09-14-2015 10:02 AM
gateway
09-10-2015 04:15 PM
CPLYONS
09-07-2015 07:19 PM
Audi Other 2013 Audi RS5 (low mileage) $61,000
buiyahkah
09-07-2015 09:29 AM
