What are people here seeing for vacuum pressure at idle?
Old 09-11-2006, 05:06 AM
  #11
Member
Shep 1.8T's Avatar
gotcha...
Old 09-11-2006, 05:09 AM
  #12
DUBITUP's Avatar
Default this suck shep...I can not figure out why you'd be so low other than a leak
have you check the injectors? IIRC they look fine.
maybe time to drop off @ Autobahn Premier Service and let Randy & Todd see wht they can find. 303-935-9065
alex
Old 09-11-2006, 06:03 AM
  #13
VTB(Erik)'s Avatar
I was seeing ~17 this morning.
Old 09-11-2006, 08:05 AM
  #14
Member
Shep 1.8T's Avatar
Default well actually I could be low because of carbon build up
either things not sealing very well, or enough buildup on the top of the cylinders that they I'm not pulling as much as I should be.
I don't believe I have a leak. That would have been revealed by now... with the numerous pressure/vacuum test I have done. I'm not far off at this point 1~2 in HG of mercury, so it has to be something small.
I've got some o-rings to replace on the injectors, a motor vac /3M cleaning to do and ultrasonically clean the injectors, as well as clean the throttle plate.
Tonight I run a compression check and see how it goes.
Old 09-11-2006, 08:06 AM
  #15
Member
Shep 1.8T's Avatar
word... okay well I don't feel so bad.
Old 09-11-2006, 08:11 AM
  #16
DUBITUP's Avatar
yah, that might be it. Good luck
Old 09-11-2006, 08:12 AM
  #17
Member
Shep 1.8T's Avatar
Default thanks.. seeing as how I don't actually need a car to get to school
I'm not in the greatest of hurries. I will find/fix my problem, myself.
Old 09-11-2006, 10:58 AM
  #18
Pat
Pat's Avatar
Default Over lunch today I saw 17 inches of mercury at idle.
Keep in mind, with the car shut off the gauge reads two inches of mercury.
Old 09-11-2006, 11:07 AM
  #19
Member
Shep 1.8T's Avatar
Default so are you saying that you may be closer to 15 in HG increase upon idle?
or decrease.. whatever you want to call it.
Old 09-11-2006, 11:30 AM
  #20
Pat
Pat's Avatar
Default Yeah, I guess so. Hell who knows...
I don't think I've seen a guage default to exactly zero up here anyway.
Quick Reply: What are people here seeing for vacuum pressure at idle?
