Would I be able to pass CO emission tests with 2 O2 codes related to my piggie pipes?
They used to use an OBD scanner to check the readiness, but it's been a while. Basically, when you clear the CEL, it resets the readiness codes. Takes 50 miles or so of driving to get them to adapt.
I'm not a VAG guru, but is there something I'm supposed to do to keep them cleared? They shop relocated the 02s, but I've had this CEL ever since then. I have some small pin holes in the welds where I can see exhaust is getting out, and I tried swapping the sensors around too. Thanks for the insight!
my cel was on but i dont know if it is the programming that flagged a code they couldnt find or what but they still passed me. that was in mid august
<ul><li><a href="http://www.aircarecolorado.com/elements.htm#Visual%20Inspection">http://www.aircarecolorado.com/elements.htm#Visual%20Inspection</a</li></ul>
bballfreak
9
04-14-2019 06:59 PM
iamdrewseph
10-01-2015 11:33 AM
