Acc & Break guard unavailable
I have a problem with my RS6. I got an error saying ACC & Breaking Guard not available.
Here is copy from scan. Can someone please help me out here.
Friday,31,August,2018,17:27:04:13974
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 18.2.1.2
Data version: 20180518 DS287.1
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 1B 20 22 28 36 3B
3C 42 44 46 47 52 53 55 56 5F 62 65 6C 6D 72 85 88 89 8B 8E
8F 90 BA
13-Auto Dist. Reg -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
3C-Lane Change -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
85-On Board Cam. -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: Malfunction 0010
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Serial number: 00000000000000
Coding: 7E04010102
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 285FC41C53C58D044F-807C
1 Fault Found:
145152 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 52
Mileage: 95622 km
Date: 2018.05.18
Time: 20:38:18
Control Module temperature: 28 °C
Voltage terminal 15: 14.599 V
Velocity_vehicle_reference: 9.52 m/s
Longitudinal_acceleration_vehicle_reference: 0.73 m/s²
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000001040954
Coding: 00E5074800
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 71E9E978A09F8CCCD8-8024
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 5257710903
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 130605000000000002C5
1 Fault Found:
0267 - Optical data bus
U1049 00 [008] - Open circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 91
Mileage: 96280 km
Date: 2018.08.16
Time: 12:15:15
Voltage terminal 30: 11.8 V
Voltage terminal 15: 0.0 V
Control Module temperature: 30 °C
System status: Awake_Timer_active
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 K HW: 4G0 907 566
Component: J769 SWA MasterH04 0010
Revision: 00H04000 Serial number: 6PZ 010 287-09
Coding: 0000105
VCID: 377D1760467B12FCD6-8062
Subsystem 1 - Part No: 4G0 907 568 K
Component: J770 SWA Slave H04 0020
Subsystem 2 - Serial number: 6PZ 010 287-29
Subsystem 3 - Serial number: 5F24.07.1300H04000AMS14115ÿ
Subsystem 4 - Serial number: S14115ÿ
2 Faults Found:
02856 - Sensing Area for Control Module 2 Blocked
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 73
Mileage: 95622 km
Time Indication: 0
Date: 2018.05.18
Time: 20:38:17
02850 - Control Module 2 for Lane Change Assistance (J770)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 52
Mileage: 96299 km
Time Indication: 0
Date: 2018.08.17
Time: 19:14:09
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 130729-0002-015
Coding: 1122A6601002B300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 2D5135087C27A82CBC-8078
1 Fault Found:
764928 - Left/Right Driving Switch-Over Active
C1080 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 7
Mileage: 94464 km
Date: 2018.03.08
Time: 16:45:57
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 Q HW: 4G0 035 670 H
Component: H-BNT-EU H51 1034
Revision: -------- Serial number: 190G+0D7546733
Coding: 070100010303E9EF7DB0CB1E00000003080001000000000000
VCID: 31692978681FCCCC98-8064
Subsystem 1 - Part No: 8R0 060 884 BC
Component: EUR 2013/2014 1603
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD001RRB8
Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
Component: E380 BDT C7 H11 0204
Serial number: 90349MGM000FI
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5298
1 Fault Found:
02067 - Optical Databus; Unpermitted Wake-Up Request
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 91
Mileage: 96280 km
Time Indication: 0
Date: 2018.08.16
Time: 12:12:13
Freeze Frame:
Voltage: 11.80 V
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 HW: 4H0 907 273
Component: RDKBERU25 H09 0700
Serial number: 10000000003796
ASAM Dataset: EV_RDKBERU25 003014
ROD: EV_RDKBERU25_AU57.rod
VCID: 68DF841C93454D048F-803C
1 Fault Found:
12652551 - Tire Pressure Monitoring
C10DC 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 64
Mileage: 94879 km
Date: 2018.03.28
Time: 14:25:15
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Revision: -------- Serial number: 262130025421000
Coding: 6A060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 2643CA2459D19B747D-8072
1 Fault Found:
0001 - Front Heater for Lane-Holding Assist
C1101 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 90
Mileage: 94658 km
Date: 2018.03.14
Time: 13:14:56
Outside air temperature: -47.0 °C
Voltage terminal 15: 13.9 V
Control Module temperature: 36.0 °C
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7E04010102
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X_002.rod
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 52
Mileage: 95622 km
Date: 2018.05.18
Time: 20:38:18
Control Module temperature: 27 °C
Voltage terminal 15: 14.578 V
Velocity_vehicle_reference: 9.19 m/s
Longitudinal_acceleration_vehicle_reference: 0.69 m/s²
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000121707137
Coding: 04C0BB1B1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
1 Fault Found:
0063 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 52
Mileage: 95622 km
Date: 2018.05.18
Time: 20:38:19
Outside air temperature: 18.5 °C
Voltage terminal 15: 14.6 V
Last scan with hex-net. Scan - Clear - scan before driving. Some of the faults did not show up on this one compared to the one I posted yesterday.
I am complete new to this but what I find interesting is that the control module 2 for lane change fails at 20:17:08. A few seconds later all the other fails come up.
Code:
Wednesday,05,September,2018,20:21:05:25183 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4411.4 Data version: 20180518 DS287.1 www.Ross-Tech.com VIN: WUAZZZ4G4EN900924 License Plate: Chassis Type: 4G-AU57 (4G0) Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 1B 20 22 28 36 3B 3C 42 44 46 47 52 53 55 56 5F 62 65 6C 6D 72 85 88 89 8B 8E 8F 90 BA VIN: WUAZZZ4G4EN900924 Mileage: 96590km-60018miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: Malfunction 0010 14-Susp. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1B-Active Steering -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 22-AWD -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3B-Sensor Elect. -- Status: OK 0000 3C-Lane Change -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 85-On Board Cam. -- Status: OK 0000 88-Multicont. Seat Driver -- Status: OK 0000 89-Multicont. Seat Pass. -- Status: OK 0000 8B-Adaptive Cruise 2 -- Status: Malfunction 0010 8E-Image Processing -- Status: Malfunction 0010 8F-Pretens. Frt Left -- Status: OK 0000 90-Pretens. Frt Right -- Status: OK 0000 BA-Motor Mounts -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (------CRDB) Labels:. 06E-907-551-CGW.clb Part No SW: 4G0 906 560 HW: 4H0 906 014 Component: 4.0l V8TFSI / H62 0012 Revision: NCH62--- Coding: 122A003265460B0A1000 Shop #: WSC 30477 001 1048576 ASAM Dataset: EV_ECM40TFS0114G0906560 001013 ROD: EV_ECM40TFS0114G0906560.rod VCID: E582E9C4E403196C34-80B0 No fault code found. Readiness: 1110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb Part No SW: 4G0 927 158 BD HW: 0BK 927 156 AM Component: 0BK 40TFSIRdW H16 1001 Revision: --H16--- Coding: 000001 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMAL551211 002022 ROD: EV_TCMAL551211_002_AU48.rod VCID: F1AA8D9420CBC5CC58-80A4 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb Part No SW: 4G0 907 379 P HW: 4G0 907 379 P Component: ESP PREMIUM H09 0100 Revision: -------- Serial number: -------------- Coding: 64BF990126FD9980CB00 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_ESPPremiAU57X 004036 ROD: EV_ESPPremiAU57X_004_AU57.rod VCID: BE3066A821156AB495-80EA No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 4H0 907 064 FP HW: 4H0 907 064 DP Component: BCM2 2.0 H35 0560 Revision: 00002001 Coding: 05A92F06000000000000 Shop #: WSC 29611 001 1048576 VCID: FCB4ACA07F89B8A4FB-80A8 No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass (J521) Labels: None Part No SW: 4G8 959 760 C HW: 4G8 959 760 C Component: MEM-BFS H04 0154 Revision: AA000000 Serial number: 00000068403756 Coding: C018320085006201010001010101112030303333283333 Shop #: WSC 02391 785 00200 VCID: BA386AB8353D4694A9-80EE No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb Part No SW: 4G0 820 043 AF HW: 4G0 820 043 AF Component: KLIMA 4 ZONEN H13 0087 Serial number: 17071300040848 Coding: 688200BE05 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirCondiComfoUDS 002040 ROD: EV_AirCondiComfoUDS_002.rod VCID: E386F7DCEA37675CDA-80B6 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb Part No SW: 4H0 907 063 CG HW: 4H0 907 063 Component: BCM1 2.0 H12 0130 Revision: 11012002 Serial number: 00000001758334 Coding: 0907201009749FF2B98100C4A0001800CF9CC7082E080201800108546F01 Shop #: WSC 02391 785 00200 VCID: EFAE8BEC3EFFD33C4E-80BA Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB Component: WWS57X 130628 H36 0080 Serial number: 130717215131 Coding: 0045F7 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 21579041 Coding: 0200FD Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S Component: E1 - LDS H07 0044 Serial number: 24 07 2013 00000052 Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B Component: A31 LED Mod1L H03 0006 Serial number: 00000012071300010871 Coding: 110000 Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B Component: A27 LED Mod1R H03 0006 Serial number: 00000012071300010714 Coding: 110000 Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C Component: EVLS-SG H08 0300 Serial number: WA107413000004178965 Coding: 020300 Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H03 0003 Serial number: 5ED84CB6000000000001 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb Part No SW: 4H0 919 475 AC HW: 4H0 919 475 AG Component: PARKHILFE ACC H01 0091 Revision: 11001001 Serial number: 61031319600003 Coding: A8EB1B Shop #: WSC 02391 785 00200 ASAM Dataset: EV_EPHVA18AU57X0000 004009 ROD: EV_EPHVA18AU57X0000_004.rod VCID: F3A6879C5AD7F7DCAA-80A6 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb Part No SW: 4G0 907 561 A HW: 4G0 907 561 Component: ACC3 H19 0410 Serial number: 00000000000000 Coding: 7E04010102 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AdaptCruisContrAU57X 002010 ROD: EV_AdaptCruisContrAU57X_002.rod VCID: A81CA0F0D391C404CF-80FC 1 Fault Found: 145152 - Function Restriction due to Faults in Other Modules U1113 00 [009] - - [FAULT_CIS_SWA_FAIL] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 61 Mileage: 96590 km Date: 2018.09.05 Time: 20:17:10 Control Module temperature: 41 °C Voltage terminal 15: 14.090 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² ------------------------------------------------------------------------------- Address 14: Susp. Elect. Labels: None Part No SW: 4G0 907 376 HW: 4G0 907 376 A Component: J250 DRC FahrwerH01 0040 Revision: 00000000 Serial number: 00894015077400 Coding: 0000000 Shop #: WSC 02391 785 00200 VCID: EB969FFCCAE72F1C62-80BE No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 4H0-959-655.clb Part No SW: 4H0 959 655 C HW: 4H0 959 655 C Component: Airbag10.43 H43 0040 Revision: -------- Serial number: 003JG00EDNUW Coding: 30323436313330303335554A304C34473053 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirbaAU10BPAAU64X 001014 ROD: EV_AirbaAU10BPAAU64X_VW51.rod VCID: B6207E880925A2F44D-80E2 Crash sensor for side airbag: driver side: Serial number: 3575HRB401250J0K91CJ Crash sensor for side airbag: front passenger side: Serial number: 3585HRB401250J0K694H Crash sensor for side airbag: rear: driver side: Serial number: 3515JRB401650KJOJ142 Crash sensor for side airbag: rear: passenger side: Serial number: 3525JRB401C50KRAFH1C Crash sensor for front airbag: driver side: Serial number: 3554VRB400U50M2EPH2Z Crash sensor for front airbag: front passenger side: Serial number: 3564VRB400U50M2ENH9+ No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb Part No SW: 4H0 953 568 H HW: 4H0 953 568 H Component: Lenks.Modul H04 0005 Revision: -------- Serial number: 90372MGO000M5 Coding: 0004FD Shop #: WSC 02391 785 00200 VCID: B83C70B00B3154845F-80EC Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E Component: E221 - MFL H08 0010 Serial number: 03 07 2013 D0260094 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1 Part No SW: 4G0 920 931 B HW: 4G0 920 931 B Component: TBenRdwAccNv H80 0618 Revision: 30460230 Serial number: 658240713596004 Coding: 138F110BAFD50008000400 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RBD4K 004048 ROD: EV_RBD4K.rod VCID: A502A9C4A483D96CF4-80F0 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: None Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC Component: J533--Gateway H12 0037 Revision: -------- Serial number: 00000001040954 Coding: 00E5074800 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_GatewPkoUDS 001018 ROD: EV_GatewPkoUDS_001_AU57.rod VCID: F1AA8D9420CBC5CC58-80A4 Battery Monitoring Control Module: Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181 Component: J367-BDMHella H03 8041 Serial number: 5257710903 Voltage stabilizer: Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 Component: J532_DCDCStab H23 0021 Serial number: 130605000000000002C5 No fault code found. ------------------------------------------------------------------------------- Address 1B: Active Steering (J792) Labels: None Part No SW: 8K0 907 144 L HW: 8K0 907 144 L Component: DYNAMIKLENK. H06 0720 Revision: 52001005 Serial number: -------------- Coding: 010100 Shop #: WSC 02391 785 00200 VCID: B83C70B00B3154845F-80EC No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD Component: FLA H04 0012 Revision: AA001002 Coding: 040182646E6E645A5A253D3E00 Shop #: WSC 02391 785 00200 VCID: FCB4ACA07F89B8A4FB-80A8 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels: 4H0-907-163.clb Part No SW: 4H0 907 163 B HW: 4H0 907 163 A Component: 4 Wheel Drive H16 0200 Serial number: 001607130001788 ASAM Dataset: EV_AllWheelDiffeQSPFR 003026 ROD: EV_AllWheelDiffeQSPFR.rod VCID: A81CA0F0D391C404CF-80FC No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear (E265) Labels:| 4G0-919-158.clb Part No SW: 4G0 919 158 K HW: 4G0 919 158 K Component: KLIMA FOND H07 0087 Serial number: 25071300040223 Coding: 20 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_ClimaContrUnitRearUDS 002019 ROD: EV_ClimaContrUnitRearUDS_002.rod VCID: B73E738C0E2F5BFC56-80E2 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4G8 959 760 C HW: 4G8 959 760 C Component: MEM-FS H04 0154 Revision: AA000000 Serial number: 00000068403800 Coding: C0183B0085016201010001010101112030303333203333 Shop #: WSC 02391 785 00200 VCID: BA386AB8353D4694A9-80EE No fault code found. ------------------------------------------------------------------------------- Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb Part No SW: 4G0 907 637 L HW: 4G0 907 637 G Component: SARA 6D red H02 0056 Revision: -------- Serial number: EJ1BPA7E00L8ST Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SARA2 005012 ROD: EV_SARA2.rod VCID: B73E738C0E2F5BFC56-80E2 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: Redir Fail! Part No SW: 4G0 907 566 K HW: 4G0 907 566 Component: J769 SWA MasterH04 0010 Revision: 00H04000 Serial number: 6PZ 010 287-09 Coding: 0000105 Shop #: WSC 02391 785 00200 VCID: B73E738CC62F5BFC56-80E2 Subsystem 1 - Part No: 4G0 907 568 K Component: J770 SWA Slave H04 0020 Subsystem 2 - Serial number: 6PZ 010 287-29 Subsystem 3 - Serial number: 5F24.07.1300H04000AMS14115ÿ Subsystem 4 - Serial number: S14115ÿ 1 Fault Found: 02850 - Control Module 2 for Lane Change Assistance (J770) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 61 Mileage: 96590 km Time Indication: 0 Date: 2018.09.05 Time: 20:17:07 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: None Part No SW: 4G8 959 793 H HW: 4G8 959 793 F Component: TSG FA H04 0507 Revision: -------- Serial number: -------------- Coding: 011F16015E00628202080013 Shop #: WSC 02391 785 00200 VCID: C5C209444CC3396CD4-8090 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb Part No SW: 4G0 909 144 L HW: 4G0 909 144 G Component: RCEPS H38 0010 Revision: 00001000 Serial number: 0030721624 Coding: 011001010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RCEPS 009008 ROD: EV_RCEPS_009.rod VCID: B2284298E54DBED461-80E6 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb Part No SW: 4H0 907 064 FP HW: 4H0 907 064 DP Component: BCM2 2.0 H35 0560 Revision: 00002001 Serial number: 0311945686 Coding: 013A0E20A0B93081833009840C0312470000000000000000000000000000 Shop #: WSC 02391 785 00200 VCID: FCB4ACA07F89B8A4FB-80A8 Subsystem 1 - Part No: 4G0 951 177 Component: DWA-Sensor H01 0010 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135 Component: Dachelektroni H10 0100 Serial number: 0000000AP00004072828 Coding: 010000 Subsystem 4 - Part No SW: 3AA 962 243 B HW: 3AA 962 243 B Component: GEB.F.Heckoef H16 0810 Serial number: 93002366 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: None Part No SW: 4G0 035 223 C HW: 4G0 035 223 A Component: BOSE-G3-C7 H07 0160 Revision: CJ007001 Serial number: 00000000195318 Coding: 030000 Shop #: WSC 30477 001 1048576 VCID: 9D72812484D311ACAC-80C8 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: None Part No SW: 4G8 959 792 J HW: 4G8 959 792 G Component: TSG BF H03 0507 Revision: -------- Serial number: -------------- Coding: 011F16015E00628202080002 Shop #: WSC 02391 785 00200 VCID: C6C00E4871C53274DD-8092 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 4H0-907-801.clb Part No SW: 4H0 907 801 G HW: 4H0 907 801 A Component: EPB-4 H03 0014 Revision: -------- Serial number: 00000000778038 ASAM Dataset: EV_ParkiBrake 001028 ROD: EV_ParkiBrake_VW51.rod VCID: AC145CE0C769E8242B-80F8 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb Part No SW: 4H0 907 357 B HW: 4H0 907 357 B Component: ....LWR12.... H02 0010 Serial number: 130729-0002-015 Coding: 1122A6601002B300 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_HeadlRegulBasic 005001 ROD: EV_HeadlRegulBasic.rod VCID: AD1251E4FC73E12C3C-80F8 1 Fault Found: 764928 - Left/Right Driving Switch-Over Active C1080 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 61 Mileage: 96590 km Date: 2018.09.05 Time: 20:17:10 ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G1 035 053 J HW: 4G1 035 053 Component: Radio U Basic H41 0133 Revision: AB001007 Serial number: 227G$0D7836116 Coding: 010003010000000001 Shop #: WSC 30477 001 1048576 VCID: A600AEC8D185D274FD-80F2 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 4G0 035 670 Q HW: 4G0 035 670 H Component: H-BNT-EU H51 1034 Revision: -------- Serial number: 190G+0D7546733 Coding: 070100010303E9EF7DB0CB1E00000003080001000000000000 Shop #: WSC 02391 785 00200 VCID: B12A4D94E84B85CC18-80E4 Subsystem 1 - Part No: 8R0 060 884 BC Component: EUR 2013/2014 1603 Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C Component: DU8 C7 SV H43 0021 Serial number: AUZ8ZDDD001RRB8 Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q Component: E380 BDT C7 H11 0204 Serial number: 90349MGM000FI Subsystem 4 - Part No: 8R0 060 961 F Component: CD-Database 5298 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: None Part No SW: 4G8 959 795 J HW: 4G8 959 795 G Component: TSG HL H03 0507 Revision: -------- Serial number: -------------- Coding: 010F14004000628202080002 Shop #: WSC 02391 785 00200 VCID: C9DA057460DBDD0C30-809C No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb Part No SW: 4H0 907 273 HW: 4H0 907 273 Component: RDKBERU25 H09 0700 Serial number: 10000000003796 ASAM Dataset: EV_RDKBERU25 003014 ROD: EV_RDKBERU25_AU57.rod VCID: E89CE0F0131104040F-80BC No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J928) Labels:* None Part No SW: 4H0 907 428 A HW: 7P6 907 441 D Component: TopView H05 0150 Revision: 11001001 Serial number: 82330JF0098840 Coding: 0203000101010000000102000000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_CamerSysteTopViewAUDI 006025 ROD: EV_CamerSysteTopViewAUDI_005.rod VCID: AB165FFCC267EF1C22-80FE No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (----) Labels:* Redir Fail! Part No SW: 4G9 959 107 B HW: 4G9 959 107 A Component: HDSG-Modul H03 0143 Revision: 14003001 Serial number: 193300124 Coding: 097205C010 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_HDSGAu572 001022 ROD: EV_HDSGAu571.rod VCID: B52279841423A9EC44-80E0 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: None Part No SW: 4G8 959 795 J HW: 4G8 959 795 G Component: TSG HR H03 0507 Revision: -------- Serial number: -------------- Coding: 010F14004000628202080002 Shop #: WSC 02391 785 00200 VCID: C9DA057460DBDD0C30-809C No fault code found. ------------------------------------------------------------------------------- Address 85: On Board Cam. (J852) Labels:* None Part No SW: 4G0 907 217 A HW: 4H0 907 217 A Component: DPC-SG H26 0038 Revision: -------- Serial number: 262130025421000 Coding: 6A060000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_OnBoardCamerDPC 001007 ROD: EV_OnBoardCamerDPC.rod VCID: A600AEC8D985D274FD-80F2 No fault code found. ------------------------------------------------------------------------------- Address 88: Multicont. Seat Driver (J873) Labels:* None Part No SW: 4G8 881 073 HW: 4G8 881 073 Component: P2G H02 0032 Serial number: 0D6I5VQ Coding: 766FF0 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_P2GDriveSideFrnt 001006 ROD: EV_P2GDriveSideFrnt.rod VCID: EE9096E831F5DA3445-80BA Valve Block 1 In Driver Side Front Seat: Subsystem 1 - Part No SW: 4G8 907 181 HW: 4G8 907 181 Component: PSLB H02 0023 Serial number: 00000000000000000000 Valve Block 2 In Driver Side Front Seat: Subsystem 2 - Part No SW: 4G8 907 182 HW: 4G8 907 182 Component: PSML H02 0023 Serial number: 00000000000000000000 Valve Block 3 In Driver Side Front Seat: Subsystem 3 - Part No SW: 4G8 907 182 HW: 4G8 907 182 Component: PSMR H02 0023 Serial number: 00000000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 89: Multicont. Seat Pass. (J872) Labels:* None Part No SW: 4G8 881 073 HW: 4G8 881 073 Component: P2G H02 0032 Serial number: 0D6K0EW Coding: 366FF0 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_P2GPasseSideFrnt 001006 ROD: EV_P2GPasseSideFrnt.rod VCID: EE9096E831F5DA3445-80BA Valve Block 1 In Passenger Side Front Seat: Subsystem 1 - Part No SW: 4G8 907 181 HW: 4G8 907 181 Component: PSLB H02 0023 Serial number: 00000000000000000000 Valve Block 2 In Passenger Side Front Seat: Subsystem 2 - Part No SW: 4G8 907 182 HW: 4G8 907 182 Component: PSML H02 0023 Serial number: 00000000000000000000 Valve Block 3 In Passenger Side Front Seat: Subsystem 3 - Part No SW: 4G8 907 182 HW: 4G8 907 182 Component: PSMR H02 0023 Serial number: 00000000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb Part No SW: 4G0 907 541 A HW: 4G0 907 541 Component: ACC3 H19 0400 Serial number: 00000000000000 Coding: 7E04010102 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AdaptCruisContr2AU57X 002008 ROD: EV_AdaptCruisContr2AU57X_002.rod VCID: A600AEC8D985D274FD-80F2 1 Fault Found: 145152 - Function Restriction due to Faults in Other Modules U1113 00 [009] - - [FAULT_CIS_SWA_FAIL] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 61 Mileage: 96590 km Date: 2018.09.05 Time: 20:17:10 Control Module temperature: 40 °C Voltage terminal 15: 14.200 V Velocity_vehicle_reference: -0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² ------------------------------------------------------------------------------- Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb Part No SW: 4G0 907 107 E HW: 4H0 907 107 Component: BV-SG H32 0041 Serial number: 005000121707137 Coding: 04C0BB1B1111 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_BC7 001001 ROD: EV_BC7.rod VCID: A81CA0F0D391C404CF-80FC 1 Fault Found: 0063 - Function Restriction due to Faults in Other Modules U1113 00 [009] - - [SWA_Signal_error] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 61 Mileage: 96590 km Date: 2018.09.05 Time: 20:17:10 Outside air temperature: 19.5 °C Voltage terminal 15: 14.3 V Control Module temperature: 42.0 °C ------------------------------------------------------------------------------- Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb Part No SW: 4H0 980 945 B HW: 4H0 980 945 C Component: RGS-VL H13 0080 Coding: 0066E608031F0376070308014240C0010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_L 002004 ROD: EV_RGS_L.rod VCID: B12A4D94E04B85CC18-80E4 No fault code found. ------------------------------------------------------------------------------- Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb Part No SW: 4H0 980 946 B HW: 4H0 980 946 C Component: RGS-VR H13 0080 Coding: 0066E608031F0376070308014240C0010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_R 002004 ROD: EV_RGS_R.rod VCID: B2284298E54DBED461-80E6 No fault code found. ------------------------------------------------------------------------------- Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb Part No SW: 4H0 907 145 HW: 4H0 907 145 Component: AEM - LEAR H07 0006 Revision: 00001001 Serial number: 97809002304700 ASAM Dataset: EV_AEMLearAU64X 002014 ROD: EV_AEMLearAU64X.rod VCID: E680EEC8190512743D-80B2 No fault code found. End----------(Elapsed Time: 03:14, VBatt start/end: 14.3V/14.2V)-----------
Took it to the local Audi dealer today and they had it for one hour. They say the slave control modul is gone. New module and calibration is needed. Hopefully this will solve the problem. ill let you know. Thanks for help!
- 02850 - Control Module 2 for Lane Change Assistance (J770)
RamblingMan
A6 (C7 Platform) Discussion
09-22-2019 08:52 AM
koalaballa
10
08-24-2014 06:36 PM
samthemana8
20
05-01-2014 06:03 AM
